Car Audio & Video Logo
Posted on Jun 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display is out on KDCX590. Someone (tech48) said the problem is not head unit but inside main unit and that something could be soldered...Need directions please.
Anonymous
Level 3:
President:
  • Master 624 Answers
  • Posted on Jun 17, 2008
Anonymous
Master
Level 3:
President:
Answers
624
Questions
6
Helped
278083
Points
2008
I would need to look at the service manual to be sure this model number is the same problem, but I think it is.
If you take the radio out of the car and open the top on it by removing the gold screw on top near the back middle, the top metal plate will pull off and you will see the cd player.
After that you look into the cd player and it is held in by 2 gold screws. One on each corner in the front of the cd player. After removing those 2 screws you will be able to take out the cd deck. Be careful pulling it out, you can damage the ribbon cable connecting it to the main board. Set it over to the left and look into the unit on the main board at the front right area of the board. If you see a series of surface mount resistors, this is the same fix as the other model. If there are not a series of resistors the problem is something else. Maybe the connector for the display or the lcd itself.
Those surface mount resistors need to be resoldered. If you do not know how to properly resolder them, I advise you to take it to a service center to have it done. If you do know how to resolder surface mount components then go ahead and give it a try. Make sure you don't make any solder bridges that could short out another component.
Those surface mount resistors are heat stressed and need a touch of new solder put on them. You can do it without taking the main board out of the unit. They are on the top side of the board in plain site in the front right corner all lined up one after the other and in one spot two that are side by side.
I have fixed this problem over a hundred times, It applies to several models, but I can't remember off the top of my head if yours is also one of them, but it does ring a bell.
I will check in the service manual tomorrow when I am at work and get back with you if it is something different.
My Sony amplifier protection flashed a few times and I reset it each time properly. When I turn it on now everything clicks and displays come up and no protection warning, but no sound, at all.
Fuses only blow when there is a short circuit. In your case it sound like the main amplifier has been playing up and tripping the circuit. But now something has gone completely, but no longer trips the protection circuit. I would have a look inside and pay close attention to the main power amp board. If there is an IC on it suspect that.
1helpful
I have a kdc mp632u and i cant get any sound out of my subwoofers. The amp comes on and there is power to the amp but still no sound. can someone tell step by step what i have to do to get it to work with...
First, make sure that the RCA's from the HU to your amp are properly connected, and fully seated on both ends. There are 2 sets of outputs. You should be using the ones on the left as you face the rear of the HU. Here is a link to the manual. Page 40 shows the connections on the back:
http://inform3.kenwoodusa.com/manuals/KDCX590.pdf
After making sure that everything is connected OK, check to see if you have the subwoofer output turned on your MP632U.
To do this, push the control knob on the right toward AM (toward the bottom). Subwoofer output switches off/on each time you push it. When it is on, the display reads "SW ON".
If this does not solve the problem, you most likely have a defect in either the HU or the amp.
Hope this helps! If it does, please rate as "FixYa." Thanks!
79helpful
10answers
Kenwood KDC-X590 Faceplate display problem
Yes, the problem is inside the main unit. I have fixed hundreds of these radios over the years.
The solder on these resistors get heat stressed and stop conducting properly. They just need a tiny little touch of solder.
With the radio in front of you and the face is facing you, take the top off and remove the CD mech. The CD mech can just be set over to the left a little and the ribbon cable to it can stay connected. Just move it out of the way gently. You will see a series of resistors in the right front corner area of the main board on top. They have 2R7 printed on them and there are quiite a few, all in that main area. Just resolder them and put it all back together again and the display will work normal.
Dave
Kenwood kdc-mp532u Auxiliary?
http://inform3.kenwoodusa.com/manuals/KDCX590.pdf - Manual
iPod Adapter Compatible: Using the KCA-iP500 iPod Control Interface, you can connect your Apple iPod digital music player to this receiver. The interface (item # 113IP500) plugs into the receiver's 13-pin CD changer input and controls the iPod through the receiver's controls, as well as displays the iPod's text information right on the receiver's display.
Display is OUT but everything functions....... what to do?
I just followed tech48's solution by resoldering the resistors on the main board.
16helpful
5answers
KDC-MP532U display blank
Solution from Tech48:
The problem is not the faceplate for any of you, it is inside the main unit. If you know how to solder, you can fix is very easy. First take the top off the unit, there is 1 screw in the back middle. Then take the CD player out. It has 2 screws holding it in at the front corners at the bottom of the CD deck. Use a number 2 phillips and take out the gold screws holding the CD deck in place. Then you can pull out the CD deck, and be careful not to damage the ribbon cable connected from the CD deck to the main board. The deck can just sit up and over to the left to get it out of the way for what needs to be soldered.
Look inside the main unit on the board and you will see in the front right corner a series of surface mount resistors all connected in series. Just reflow that solder on them with a small amount of new solder added and the display will once again work perfectly. That solder is very heat stressed, that is the problem. I have fixed dozens of these over the last few years. Make sure you put it back together the same as it came apart, and you are done.
Sony STR-DE445 protect displayed
It sounds like a bad solder connection. It just needs to be soldered up, if you take it into a shop just tell them it doesn't need any new parts, it just needs to be soldered up.
Or, if you can solder it yourself, or know someone that can, that would be much easier.
2helpful
2answers
Display on Kenwood Out
I am not sure exactly what solution you are reffering to, but the KDC-MP532U has a problem with the display going out that is the result of heat stressed solder on the main board. The surface mount resistors that are located on the right side near the front of the unit, as you look into it with the display facing you, are the culprits. This is common in about 3 or 4 Kenwood models. These surface mount resistors are on the top of the board, so the board doesn't need to be taken out to fix it. Just the CD mech does. The surface mount resistors just need the solder reflowed, an easy enough job if you know how to solder. They are all lined up connected to each other, I don't remember the reference numbers, but if you can recognize what a surface mount resistor looks like, you should be able to find them very easy.
Thanks for the compliment on the other post, it is appreciated. A good rating would also be appreciated.
Thanks and good luck,
Dave
33helpful
10answers
No display on my kenwood kdc-mp532u
I read up on this and saw Tech48's post related to a different model. He's the one who deserves the credit. I'm just the rookie who has the soldering iron. However, here's a picture of the 5 resistors that you need to reflow and "top up"
My model is the KDC-MP532U (same as the 532, but with the USB option).
Here's the overall view. The CD-Player is standing on its edge at the bottom. The resistors are on the bottom right by the brass screw post.
...and here's a close up of the board and the resistors....
Hope it helps. Thanks Tech48!!!! It's like I've got a new stereo!!
94helpful
23answers
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
