Question about LG MG64 VHS VCR
HI! I have LG LV 4260 vcr. How to change the uhf channel signal to tv? Thx
5 Suggested Answers
SOURCE: 42LC2DR
You need to press the button on the top right of the control ( the TV button) once and that will allow you to control the tv once again. Problem occurs when you accidently push VCR or DVD button which means remote control will try a different frequency to operate a VCR or DVD that isn't there. Hope this helps.
Posted on Sep 18, 2008
uzs3702
SOURCE: LG 26inch LCD tv
hhh
Posted on Jan 25, 2009
chanddra2009
  • 615 Answers
SOURCE: changes channel by its self it goes crazy
You have ONE of two possibilities....on the Front panel buttons, you MIGHT have a stuck button or leaky button....
I suspect that if ALL it does is change channels...it would be a channel UP or DOWN button stuck....yes, it can fire up the tv too....But it will dedicate itself to doing only ONE function.
IF you have multiple operations, like changing channels, menu appearing, volume changing....then the MOST likely problem is actually the microprocessor causing the problem....BUT it is STILL possible to have SEVERAL buttons stuck....rare, but possible.
And unfortunately unplugging it won't even help in any of these possibilities....
You have to start with pressing each and every button one at a time and see if the problem stops afterwards....
IF it doesn't, then the next step is to measure the resistance across each button....they should read Infinite ohms.
If any measure lower, the button should be removed and see if the TV acts normally...
IF the buttons are located on a separate board with a plug that can be disconnected, you can just disconnect that while it's acting up and see if the problem disappears.....
If it still misbehaves after this, you NEED to get it to a TV tech for further analysis with a scope.....
Posted on Jul 08, 2009
SD Tech
  • 14553 Answers
SOURCE: LG 32LH3000 is turning off when changing the channel
Do you have a box of some sort in line to the set for signal?
Posted on Dec 13, 2012
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Sep 14, 2008 | Sony KV-27FS13 27" TV
Connect vcr to jvc c2033us tv
You will need to put your aerial into the rear uhf socket of the VCR then take another connecting lead (flylead) from the out of the VCR & put this into the aerial socket of the TV. You will now need to select a channel on the TV (best to use channel zero) & tune the TV to the VCR signal. The best way to do this is to put in a recorded tape eg a film /press play/ then tune the TV until you pick up the playback of the film, then store this on the TV. This will give you your VCR channel. You will now need to tune the VCR to your broadcasted stations so that you can record.
Apr 01, 2009 | JVC Televison & Video
Can't record from lcd to vcr
On any VCR/TV setup, the television does not send signals to the VCR, the VCR has to send the signal to the television and then the show can be recorded. Attach the antenna input to the VCR and then your other cables (they may be RCA jacks or another coaxial, like the antenna cable) to the TV. You would have to change the channels using the VCR's TV tuner (if it has one).
If it does not have one, then you would need a new digital TV converter, and you hook this up to the VCR, then to the TV set. Hope this helps!
Mar 14, 2009 | LG Televison & Video
Tv/vcr combo wrong cable channels
This could be one of two problems, either the TV tuner card is set up to accept the wrong type of signals (which normally can be changed in the menu of the television) or the card isn't capable of translating the signal (with most cable companies going over to digital signals with their boxes translating the signals over.) My suggestion is to check to make sure the proper signal type is set in your menu (if in fact this is even an option for this particular television) and if that doesn't work get a generic analog digital cable box.
Sep 12, 2008 | Philips 43PP9202 43" Rear Projection...
JVC HR-D337MS Multisystem VCR - NO SIGNAL The only information I could find on the internet was it was worth $450.00 in 1991. i hooked up the RF out to RF on the TV in. Pushed play on the VCR. No signal....
Connect RF out of VCR to Antenna IN of TV. There should be a Test Signal switch at rear of VCR. Push it to ON. JVC VCRs generally generate a RF signal in the UHF band, around channel 36. Scan all channels on your TV, you should gete a Test signal of 2 parrallel black bars around channel 36. That is the Channel on which you can view tapes. Switch off 'Test signal' at rear of VCR, and press play. you should be able to watch your tape.
Jul 14, 2008 | Televison & Video
No cable
try going into the menu of the tv and changing the tuner type from ANT to Cable
Jan 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Orion model vpdc connection problem
Most, if not all, TV sets which have a tuner section (will tune in individual channels either off an antenna, cable system etc.) should be UHF capable. UHF channels are approximately channels 14 - 83 of the standard broadcast spectrum, unless this has now changed with HDTV or other RF spectrum changes by the FCC. These channels are not the same as the cable channels, for which the mode of the TV set must be set.
Anyway, you will connect the VCR to the RF input of the TV, and set the TV for non-cable mode (broadcast). You will likely need to set the TV for a particular channel which matches what the VCR sends the signal out on.
I assume also the VCR doesn't have composite video out & audio out jacks on it? If it does, these hookups can be made to matching connections on the TV.
Hope this helps.
Nov 05, 2007 | Televison & Video
42LC2DR
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
How to tune an old Television
If you are in the US, the TV set has to be on channel 3 or 4, if your in the UK, the TV would have to be on a UHF channel. It should say on the RF output of the VCR what station you must tune to ,or in the instruction book of the VCR. Good Luck
Mar 25, 2007 | Philips 26PW6341 26" TV
LG MG64 VHS VCR Logo
121 people viewed this question
Computer Repairing
Computer Repairing
