Question about Ge Medical Systems Medical
I'm looking for a GE Logiq 9 Service Manual, I'm trying to get the specs of the system, such as software and features loaded. Also I'm having an issue, whenever I try to test probes, it goes well for a while, and suddendly the system shuts down completely, the main power switch in the back of the ultrasound, flips to the off position, and do not know what could be causing the problem. As a background, this system was brought to the US from Europe, so there is a Connector that you switch for changing the Power Configuration to 120VAC 50/60Hz instead of the 240VAC 50/60hz from Europe. This is changed already with no issues. It seems that the power problem had been there before bringing the system here.
    Genius:
  • 1,035 Answers
Possible system needs to be setup for the alteration on power . try entering on pc the specs and name in search box. you might be pleasantly surprised with. information web site .
Posted on Oct 30, 2018
  • 979 Answers
SOURCE: RX V670 Yamaha Receiver-No big display, No amplification
It is entirely possible that your display tube has gone on the fritz. We see it a lot...accordianman
Posted on May 01, 2008
MORRISS
  • 40 Answers
SOURCE: Logitech S520 mouse and keyboard Screensaver and power shut down
Not a solution but it may bring some light to the problem,
There is some program calling windows every 10min or so... that's why your screen saver gets interrupted. You might need to check which program is it. Or guess it out.
Hope it helps, if you have more doubts feel free to ask.
Posted on Jan 03, 2009
  • 31 Answers
SOURCE: furnace shuts down, will not start up again
Yeup, sounds like a natural draft. A power vent system vents out the side of the house without a chimney, but because there is no draft of hot air rising up a chimney, a powered fan is used. Power vents have additional sensors that can cause the burner to shut down.
If the burner does fire but then shuts down it sounds like the flame sensing rod is not working. It is dirty or needs replacement. Are there any error codes when the burner shuts down, or an indicator lamp that shows when the controller detects a flame?
Posted on Jan 08, 2009
  • 71 Answers
SOURCE: ECG Schiller AT1 shuting down in work
Most likely needs a new battery. Can be ordered from R&D batteries.
Posted on Jun 03, 2009
SOURCE: Monitor goes blank randomly
It is the capacitor on the power to the monitor. I have replaced about 5 so for. The capacitor is like 69 cents. Open it up and look at the circuit board where the power plugs into and see if any capacitor are bubbled up. If so then its a bad capacitor.
Posted on Jul 10, 2009
I need Dimensions for a Dewalt Table Saw (DW 745-QS Type 4 2014 09-CT 001414) i want to fit it into a Woodwork Bench I am Building
Rollover image to zoom
  • + 7
DW74510" COMPACT JOB SITE TABLE SAW WITH SITE-PRO MODULAR GUARDING SYSTEM
4.6
(9)
WRITE A REVIEW PRINTThe DW745 10" Compact Job Site Table Saw with Site-Pro Modular Guarding System features tool-free guarding component adjustments and fast, accurate fence adjustments. 20" of rip capacity to handle large materials. Compact and lightweight with a metal roll cage for jobsite durability.
READ MORE BUY NOW SHARE THIS PRODUCT: SERVICE
  • FIND PARTS
  • DO YOU OWN THIS PRODUCT?
  • IMPORTANT LINKS FEATURES & SPECS
    FEATURES
    • Site-Pro Modular Guarding System allows for tool free adjustments of the guarding components appropriate for each application
    • 20" of rip easily cuts a variety of larger shelving and trim materials
    • Rack and pinion fence rails make fence adjustments fast, smooth, and accurate
    • Telescoping fence rails retract to create a small, portable package
    • On-board storage provides easy access to the Site-Pro guarding components and push stick when not in use
    • Metal roll cage base offers greater durability than plastic bases
    • Shoe bevels 0° to 45° for beveled cuts
    • Weighing only 45 lbs, the DW745 can easily be moved on and off the job
    • Adjustable rear feet designed to level the saw on uneven work surfaces
    • Dust port allows for 2-1/2" vacuum hook up and minimizes clean up
    • 24T carbide blade enhances cut quality and prolongs blade life
    • Table coating reduces friction for smoother cutting
    SPECIFICATIONS
    • AMPS 15.0 AMPS
    • ARBOR SIZE 5/8 IN
    • BLADE DIAMETER 10"
    • DEPTH OF CUT AT 45° 2-1/4 IN
    • DEPTH OF CUT AT 90° 3-1/8 IN
    • DUST PORT DIAMETER 2-1/2 IN
    • MAX RIP TO LEFT OF BLADE 12 IN
    • MAX RIP TO RIGHT OF BLADE 20 IN
    • MAX WIDTH OF DADO N/A IN
    • NO LOAD SPEED 3,850 RPM
    • POWER TOOL TYPE CORDED
    • TOOL WEIGHT 45 LBS
    INCLUDES
    • Miter Gauge
    • Push stick
    • 10" 24T Carbide Blade
    • Blade Guard
    WARRANTY & SERVICE INFORMATION INSTRUCTION MANUAL LOOKING FOR SERVICE? EXPLORE PRODUCTSACCESSORIES
    • ACCESSORIES
    ?????No rating value
    LARGE DIAMETER PRECISION SAW BLADES
    VIEW SERIES ?????No rating value
    LARGE DIAMETER CONSTRUCTION SAW BLADES
    Nov 07, 2018 | Dewalt Saws
    I have a logiq laptop and i can't get my webcam on,or i need to update the software,how do i do this?
    1st You download Webcam Driver.
    After this install the Webcam driver in the system.
    Installation of Webcam Driver
    Go to the control panel
    Click on the System Icon
    Click on the Hardware Tab
    Click on the Device Manager s
    Select the Unknown Device or printer device where yellow Question Marks sign on it.
    Right click on it and uninstall it.
    After this go to the top of the device manager and click on scan for hardware changes.
    Driver installation Wizard start.
    Brows Your Driver from the Hard Disk and click on next.
    Driver will be install.
    Jan 02, 2013 | Logitech Webcam
    I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
    Specs are:
    Capacity
    Oven Capacity (cu. ft.): 1.6
    Features
    Wattage (IEC-705 Test Procedure): 1000
    Cooking System: CircuWave™ Plus
    Power Levels: 10
    Style: Over-The-Range
    Clock: Plus AM/PM pad
    Electronic Scrolling Digital Display: Yes
    Electronic Touch Controls: Yes
    Kitchen Timer/Timer (On/Off): No/Yes
    Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
    SmartControl System - Concurrent Programming: Yes
    SmartControl System - Help Pad: Yes
    Beverage (Convenience): Yes
    Cook (Convenience): 9 Codes
    Popcorn (Convenience): Yes
    Reheat (Convenience): 6 codes
    Add 30 Seconds: Instant-On
    Child Lock: Yes
    Cooking Complete Reminder: Yes
    Defrost Type: Auto & Time
    Delay Start: Yes
    Display On/Off: sub-pad w/ zero
    Express Cook: Instant-on 1-6
    Reminder (24 hr): Yes
    Time Cook: I & II
    Time Preference: Control Enhancement (1/9)
    Turntable: Glass
    Turntable On/Off: Yes
    Turntable Size (in.): 13-1/2
    Cooktop Lighting: Bright/Night/Off
    Night Light: Auto
    Rack Type: Wire Oven Rack
    Sound Volume Control: 4 levels
    Easy Mount Installation: Yes
    Exhaust Fan: 2-Speed
    Appearance
    Case Color: Black
    Color Appearance: Stainless Steel
    Door Color: Black/Stainless Steel
    Handle: Designer-Style
    Weight And Dimensions
    Approximate Shipping Weight: 63 lb
    Overall Depth: 15 5/8"
    Overall Height: 16 3/16"
    Overall Width: 29 7/8"
    Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
    Power/Ratings
    Electrical Input - 120V Amperage: 15
    Electrical Input - 120V Watts: 1480
    Frequency (MHz): 2450
    May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    Turn off daily alarms
    Sounds like a trouble alarm. Try this manual page 39. Hopefully this is the type panel you have if not let me know of any writing, model numbers etc that could help me identify the specific panel.
    http://www.gesecurity.com/portal/GESDownload?ID=4261&DID=4251&documenttype=User Manual
    May 24, 2010 | GE Security Simon 3 Wireless Home Security...
    Lost my Software
    The keyboard should not need anything more that what the operating system has already.
    Have you tried it?
    If there is something missing - did you really need it?
    Try the GE Compact website if you are really stuck for a download
    Dec 19, 2007 | GE Compact Office Keyboard HO97978
    Medical Logo
    433 people viewed this question
    Top Ge Medical Systems Medical Experts
    Harrie
    ka4iup
    ka4iup
    Argospete
    Argospete
    Are you a Ge Medical Systems Medical Expert? Answer questions, earn points and help others
