Question about HP LaserJet 1320n Printer
HP 1020 printer is printing horizontal black lines. Have run cleaning and physically cleaned printer where I can reach in behind the toner cartridge
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Replace toner catrtidge (blade is not doing its duty)
pls. vote for better service
Posted on Nov 11, 2010
Black lines
Replace the toner cartridge :-)
Apr 05, 2014 | HP LaserJet 1020 Printer
What is causing the black lines that I am getting on all of my printed pages?
Most of the cases vertical lines on print out causes 1. Toner cartridge 2. Fuser Teflon sleeve.. If you are replaced with new cartridge try to replace fuser teflon sleeve( only professionals can do this activity)
Jul 31, 2012 | HP LaserJet 1020 Printer
How do I manually clean my HP C7180 printer print head. The black ink prints with horizontal lines through it and is also very faint in colour. I have carried out print head cleans and alignments through...
By manual you mean that it needs windows to clean it right? (you cannot physically clean it yourself) Go to your printers, right click and in properties somewhere you should find "clean heads" somewhere. Try print test after. Should be good.
Mar 05, 2011 | HP Photosmart C7180 All-In-One InkJet...
My toner is leaving black clouds on paper what setting to clean machine please my machine is hp 1020
As far as I'm aware .... there is now cleaning procedure other than a good blown out or service. Your problem might be with the toner cartridges. If the toner has the same effect in both printers, then the toner cartridge is faulty.
Apr 13, 2010 | HP LaserJet 1020 Printer
Lines in printing
...maybe its time to replace fuser fixing film!?
Nov 10, 2009 | HP LaserJet 1020 Printer
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
Horizontal black lines across page.
Horizontal lines usually indicate a toner cartridge that is not cleaning properly.
A. If the distance between defects is 38 mm (1.5 inches), 47 mm (1.85 inches), or 94 mm (3.7 inches), the print cartridge might need to be replaced.
B. Clean the printer.
1. Clean the inside of the printer and run a cleaning page to clean the fuser.
Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems.
To clean the inside of the printer
1. Turn the printer off and unplug the power cord.
2. Open the top cover.
3. Remove the print cartridge.
4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge
cavity.
5. Reinstall the print cartridge and close the top cover.
6. Plug in the power cable and turn the printer on.
Cleaning the fuser:
Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of your print jobs. To ensure optimum print quality, HP recommends that you use the cleaning page every time that you
replace the print cartridge or on an automatic interval that you can set up. The cleaning procedure takes about 2.5 minutes to complete. A CLEANING message appears on the printer control panel display while the cleaning is taking place.
To run the cleaning page:
In order for the cleaning page to work correctly, print the page on copier-grade paper (not bond, heavy, or rough paper).
1. If your printer model includes a duplexer, open the rear output bin.
2. Press Menu to open the menus.
3. Use (Up button) or (Down button) to scroll to CONFIGURE DEVICE, and then press (Select button).
4. Use (Up button) or (Down button) to scroll to PRINT QUALITY, and then press (Select button).
5. Use (Up button) or (Down button) to scroll to CREATE CLEANING PAGE, and then press (Select button).
6. Follow the instructions on the cleaning page to complete the cleaning process.
7. If your printer model includes a duplexer, close the rear output bin.
If this helps resolve the problem, please post a reply. Binary Bob
Sep 11, 2008 | HP LaserJet 2420 Printer
HP LaserJet 1320n Printer Logo
135 people viewed this question
Seeker5211
Seeker5211
