Question about Fujitsu ScanSnap Manager
Scansnap Scanner stops suddenly when scanning multiple pages and "hangs" for a little while, stating that it's scanning the same page, before giving an error message saying that it is offline. When scanning is attempted again, we get "Undefined error occurred (0x80004005). A probable cause is that the system is unstable. Reboot the system. If this does not resolve the problem, contact the store where you purchased the scanner or an authorized service provider." Sometimes reboot it "resets"it for a little while until the same cycle is repeated, sometimes we get the error again straightaway. The scanner has a shared switch allowing two machines to share the same scanner. This problem has only occurred within the last week and is affecting both PCs it is connected to.
    New Friend:
I had this problem happen also and found that it was related to Acronis True Image Home 2011. When this program was uninstalled, the problem went away. I had even rebuilt the Windows 7-64 bit OS and the problem existed until Acronis was again removed.
Posted on Jan 22, 2013
2 Suggested Answers
SOURCE: When I try to scan,
I just fixed it. Uninstall the application by choosing applications and finding scansnap. Drag the folder to the trash. power down your scanner and unplug the USB. Go to the Fujitsu website and download the software again and reinstall it. Plug in the power and USB into your scanner and everything should work fine.
Posted on Jul 04, 2011
Testimonial: "Hi, dporcaro! Thanks so much for your advice! I did as you suggested, and it worked! I can't thank you enough! Happy 4th!"
How do I stop the scanner from scanning the blank back of the page?
Somewhere in the settings for the scanner it is set to scan both sides. You need to go into the menu and change to one sided scanning. Another possibility is that you could be putting the document to be scanned in backwards.
Jul 30, 2014 | Fujitsu ScanSnap S1500M Pass-Through...
Scans are coming out upside down
First, are you putting the pages to be scanned in upside down. If not, do so. I sometimes encounter this problem but use the free version of Adobe that comes with the scanner to turn the scanned pages right side up. Hope this helps.
May 28, 2014 | Fujitsu ScanSnap S510
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
Scanner only scans top page although set on duplex setting.
Switch the little button on top of the scanner next to the 3 buttons. This switches between 1 page or multiple page.
A.Misset
Installing these devices in the Netherlands.
Feb 05, 2010 | Canon DR-2580C Path-Through Scanner
How do i delete error pages after scaanning?
I changed the settings from duplex (double sided) scanning to simplex (single sided) scanning under the settings tab in the scansnap organiser. this was ok since i had all one-sided documents to scan. you would need to reverse this settings change anytime you have a double-sided document to scan.
Nov 18, 2009 | Fujitsu ScanSnap S510
How do I add multiple pages to one scanned doucment?
Open your Adobe Acrobat (e.g., 9.0 Pro), load your pages into the document feeder (fewer than 30 at a time), then ask Adobe Acrobat to create PDF from scanner (File/Create PDF/From Scanner). Canon MP530 as the scanner and click OK. Works like a charm!
Jul 07, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
Canon Dr-5010C Scanner to Pc problems.
Are other formats, like JPG, working okay? Unselect multiple pages so that you get on image per sheet. Reinstall scanning software after a 'scandisk' command.
S. Mohan
Mar 04, 2007 | Canon DR-5010C Path-Through Scanner
Computers & Internet Logo
1,574 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
