Hi I have a Rinnai 1004. I asked a question before about clipping the temp gauge and adding a length of speaker wire in, so that it would get a more accurate 'room' temp reading. The reason for this is that I can't get to the controls to manually change the temp. I have a few other thoughts and want to know if anyone could add to the ideas: 1. Could I add that speaker wire to the 'control unit' and mount that in a more convienient place?? 2. Would a 'plug in' thermostat work?? Something that regulates the actual power to the unit. I think it basically stops power when it's warm enough and turns it on when it cools. -since there's no pilot light, this should work right?? Thanks for any help and adivce!
  • doug_e_fr951 Nov 15, 2010
    Thank you for the ideas and considerations.
    I think I will hold off on 'extending' the controls for the moment. I'm hoping that the "plug-in" thermostat will work.
    I plan to turn the unit controls so that it will produce max (or close to max) heat. And then use a regular extension cord to plug the heater into thishttp://tinyurl.com/2ca48tc Is there any reason this shouldn't work??
    I thought that maybe turning it on and off might not be good for the heater, but I guess that's what the onboard thermostat does anyway.
    2 considerations I do have...
    1. The heater Blows hot air until the room is warm enough then stops...not like a car heater where the actual air temp is controllable at constant temp (unless I'm mistaken about this).
    2. I don't think operation should be affected because there's no pilot light and it's electronically ignited each time too.
    So I'm thinking this should work, unless there's something else that I'm not seeing.
    Thanks for your input!
  • doug_e_fr951 Nov 16, 2010
    Before I get into moving the control panel. I plan to turn the unit controls on the heater so that it will produce max (or close to max) heat. And then use a regular extension cord to plug the heater into this
    Is there any reason this shouldn't work?? I thought that maybe turning it on and off might not be good for the heater, but I guess that's what the onboard thermostat does anyway. 2 considerations I hope make this possible...
    Thanks for any input!
    Guru:
  • 773 Answers
I'm sorry. the thermostat is not in the "Temp gauge" It is inside the unit. As well, Modifying this unit can make it unsafe. As well, if one were to use wire to extend the control unit, you would want to use thermostat wire.
However this would not read the temperature where you put the control unit.
You cannot hook a wall thermostat, like one for central heat to it because this unit uses a thermistor which is completely different then how wall thermostats work.
The unit does not just shut off the power. It opens and closes valves.
You would have to find the thermistor and lengthen the wires on it and put the thermistor where you are planning to take the heat reading.
Again I highly suggest against this because it can possibly make the unit unsafe. The manufacturer lists units that are able to have a remote thermostat attached. This model is one that does not have that option available.
My suggestion to get more even heat in the room would be to use a fan to circulate the warm air throughout the room.
Posted on Nov 17, 2010
  • 757 Answers
That sounds quite plausible...and pretty good idea.
If I'm right it sounds like you simply would like to add a glorified "extension cord" to the on-board controls and thermostat to make them usable from a remote location. That could work, can't see why not. It definitely would make for a more accurate temperature reading rather than having the temperature element collecting from a mere few inches of the units' output vents.
If running it more than 30 ft cord length though, you may need to go up in wire gauge or double up on what you have if you don't have larger than about 12-10 gauge.
The only other consideration I can think of is that after you dismantle the control and temperature assembly, that when you reinstall it elsewhere that the temperature element should be oriented in the same position as it was when mounted inside the A/C chassis, i.e.; not tipped or otherwise moved from a horizontal or vertical position.
Posted on Nov 11, 2010
When the temp drops below 10degrees our Rinnai
rinnai has a technical bulletin out on this condition #28. It instructs the technician to adjust the gas pressure. You can get a copy of this bulletin by contacting rinnai at 800-621-9419 (US). or at rinnai.us
Feb 02, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai gas heater loud noise on ignition
It may be, Rinnai suggests a maximum length of about 13 equivalent feet of venting including elbows. Add 6 feet for every 90 degree elbow. If the vent is longer than this it is taxing the combustion fan motor and it will start giving you error codes and will not ignite. Remove the trim panel from behind the heater and find the flexable air intake pipe. Temporally remove it from a fitting and test the unit a few times to see if the unit starts quieter. This procedure will be taking room air into the heater for combustion and circumventing the direct vent feature of the heater, not a fix. Have you had the gas pressure tested? It gould be that! You may wish to consider relocating the heater and fire your installation contractor for putting you in this predicament, not Rinnai.
Nov 05, 2009 | Heating & Cooling
How do you fix the temp gauge it stopped working ad is stuck above the H
Hello tj60576: My name is Roger I will help you. If the temp gauge is stuck? Locate the temp sensor on the motor.Disconnect the wire. After disconnecting the wire. Ground the plug end of the wire. You can do this with a extra piece of wire. Observe the temp gauge with the key on. The gauge should move to cold side of the gauge. If the gauge still reads hot or above then the problem is either in the dash or the gauge itself. You will find the sensor located on the cross over pipe front of the engine far right hand side of the tube.
Should you need further help please just ask. Please rare the answer you received. This way I know the answer helped. Thank You for using Fix Ya. Roger
Oct 16, 2009 | 1995 Isuzu Trooper
Looking for Manuals
Google rinnai 1004 and 556 manuals. I just did and found them
Nov 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 heats to a temp 4 degrees higher than set temp, adjustment?
You can adjust the position of the room air sensor found on the back of the unit between the heater and the wall. It is a black rubber bulb with yellow wires. There is a few inches of extra wire you can extend higher to get a more accurate reading of room air. While you are back there, check for drafts that will give you false readings.
Sep 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
Behind the unit near the floor level, is a yellow wire with a black bulb at the end. This is the actual sensor for returning air. If there is cool air infiltrating the area where it is located, it will keep the unit running until the return air reaches temperature. You could also have a bad sensor but highly unlikely. Make sure there is no air infiltration influencing the sensor. Also, you can unclip the sensor and pull out a few more inches of wire to locate it higher up away from the floor. Tie it up with a wire tie.
Rinnai it testing a remote thermostat but as of yet, there is no plans to offer one.
Nov 24, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Power reset - Rinnai 1004
the rinnai is like a monitor. just unplug it, wait five min and plug it back in. then radjust your temp set point and it should pick back up. when there is a power outage the led-s flash 88:88
Nov 17, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
206 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
