How do i get to make a question mark on this key board
  • 6,831 Answers
Hello
OK, usually on a standard QWERTY keyboard you will need to hold down the SHIFT key while pressing the / key. You will see that the / key also indicates the ?.
Feel free to let me know if you need any further assistance.
Kind regards
Andrea
Posted on Nov 11, 2010
My keyboard does not generate the symbol @ from the key marked @, but from the key marked ". Also I cannot generate the currency symbol for English Pounds Sterling
It happens mate when you drop water or some liquid on the key board, or some times it may be because of dust, so you may need to open it and clean it once. if it doesn't work than i am afraid that you need to buy new one.
May 20, 2011 | Computers & Internet
In my key board m button tyed show 0 why
You probably have Number-lock active, test and see; u = 4, i = 5, o = 6, j = 1, k = 2 and l = 3.
On the bottom left of your keyboard you should find a key marked Fn. On the top right of your keyboard you should find a key marked Num LK. While pressing the Fn key, press the Num LK key once. this should unlock the number keys and allow you to type letters again.
Good luck ;)
Feb 02, 2011 | Computers & Internet
How do i use the keys that got blue on them
There will be a key marked in blue letters "Fn" likely in the lower left area of the board. It is a modifier key, similar to a shift key. Hold it down, and press whatever other blue letter key you want to use
Dec 28, 2010 | Acer NSK8458AN Keyboard
How do I remove the keys from a Roland KR 4700 piano? We can't figure it out. Please help! I can't afford to get a repairman. I need to replace the contact strip. It's happened before.
If these are semi weighted keys here is a cut and paste from a manual:
19. Disassembling the Keyboard Assembly
* After inserting a round stick (Rod: TX000670)
between the frame and the keys, remove the
circuit boards. (Fig. 23)
19-1 GHD EBUS L, MK SUB Circuit Board
(Time required: about 12 minutes)
Remove the seven (7) screws marked [260A]. The
GHD EBUS L and MK SUB circuit boards can then
be removed. (Fig. 24, Photo 5)
19-2 GHD M Circuit Board
Remove the five (5) screws marked [260B] and the
screw marked [262]. The GHD M circuit board can
then be removed. (Fig. 24)
19-3 GHD H Circuit Board
Remove the four (4) screws marked [260C] and the
screw marked [262]. The GHD H circuit board can
* Keys can be removed without removing the
circuit boards.
* After removing the GHD EBUS L, GHD M and
GHD H circuit boards, and the rubber contacts
can then be removed.
19-4 Rubber contact
Remove the GHD circuit board for the involved key.
The rubber contacts can then be removed.
The rod is inserted above the weighted hammer and the bottom of the keys from one end. It appears to be about 1/4 inch diameter dowel and will run the full length of the keyboard. You might use 3 foot ones from each end.
Screws are removed and the boards removed without taking the individual keys out.
Mar 17, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
Key board do not work
Right this is a wild shot but here we go....
If you are using PS/2 connectors for keyboard and mouse make sure they are the right way round
If you are usin USB m+k then amke sure you are using the BACK USB ports only and preferable the first two that are seperate.
Please let me know how you get on
Mark ;-)
Aug 24, 2009 | HP Compaq Business Desktop d330 Slim Tower
Toshiba equium A210 series laptop key board stops working.
GO INTO CONTROL PANAL GO TO FOLDED PROBLEM AND REPORTING AND OPEN IT
LOOK FOR ANY MARKING THAT SHOULDNT BE THERE, GREEN MARKINGS IS GOOD BUT ANYTHING ELSE TROUBLE AND DOUBLE CLICK ON THE CHECK MARK AND FOLLOW INSTRUCTIONS
ROD
Feb 12, 2009 | Computers & Internet
Key board functions
the backward slash is under the question mark key
Oct 05, 2008 | Compaq Presario Notebook
Why cant i get my question mark symbol working agian??
This is most likely a keyboard failure, but it could also be that the rubber depressor that actives the key is stuck, out of place, or dirty. Take the malfunctioning keys off, be careful and try to remove only the key, leaving the retainer on the board. Check the depressor to see if it's depressed or shifted out of place, then take the depressor out and clean the contact point on the board and the contact point in the depressor. Put it back together and try it. If the problem persists, then the keyboard is faulty and will need replaced.
Aug 01, 2008 | Acer Aspire 1640Z Notebook
Garnin 12: Half the function keys no working.
It could be that the contact on the board under the keypad are dirty. I have that problem many remote control units, I use a pencil eraser to clean the board.
Hope this helps.
Mike
Jun 07, 2008 | Garmin GPS 12 GPS Receiver
Change baud rate
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Dec 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
    Computers & Internet Logo
    15 people viewed this question
    David Payne
    David Payne
