Question about Kenmore Dryers
I have a Kenmore 70 series. model 67732791 When the start button is pushed it. The dryer turns on, it is rotating and the heat is on, however it sounds like it is dying. Then the dryer will just kick off. Can get it to run for a few minutes but will kick off again. Jennifer
mikedurland
  • 481 Answers
SOURCE: Kenmore 70 Series Dryer Won't Heat
first check your breaker, turn it off and back on.
Posted on Jun 28, 2008
  • 1122 Answers
SOURCE: kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Posted on Oct 29, 2008
  • 686 Answers
SOURCE: Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Posted on Apr 06, 2009
  • 1810 Answers
SOURCE: Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Posted on Aug 04, 2009
milten1
  • 1304 Answers
SOURCE: my kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Posted on Oct 05, 2009
Where is the fuse on kenmore dryer model 67732791? Not starting.
I don't think you should be looking for fuse. 1st check voltage at dryer.
Jul 24, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
Kenmore 70 Series Electric Dryer will not start
It sounds like the hi-limit thermostate and/or the thermal cut-off is what is causing your dryer to shut down. Basically it's over heating. You should replace these two items togeather. Also the thermal cut-off will be triggered by a grounded out heating element. Here is a diagram of where these items are located. hope this helps
Figure W-6: Dryer Rear Access
Feb 27, 2012 | Dryers
Have a Kenmore Haevy Duty 70 Series Soft Heat model #96576200, I set the time push the on button dryer comes on to start drying but shuts off within 30 seconds. Any suggestions would be appreciated
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
a
Sep 27, 2010 | Kenmore 700 6972 Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Kenmore Dryer 70 series
Hi, the problem with the dryer not stopping is most likely the switch that controls when it starts. This switch is located behind the button you would push in to start the dryer, and if you can take off the rear panel and get to it, you can most likely adjust the internal contacts so that they don't continuously make contact. Or you could just replace the switch, which might be easier!
Jul 21, 2008 | Kenmore 64742 Electric Dryer
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
147 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
