Question about GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling, no ice or water, making clicking sound
Last week, power outage in neighborhood, since then fridge not cooling, no water or ice, not cooling both sides at all
  • Anonymous Jul 19, 2008
    We have an old fridge downstairs. While we were on vacation there was a lightning strike to the ground about 60 feet from our house. There was a power outage and our neighbors switched the breaker back on. Since we'eve been back there is a clicking sound. We plugged the fridge into another outlet and it starts again but later it clicks. The freezer is not freezing so I'm bewildered as to what the problem is.Help!!
    Problem Solver:
  • 4 Answers
Sounds like the motherboard went out. Might need to replace the appliance or the board. Im not positive though. Hopes this helps....
Posted on Jun 20, 2008
Chefmate mini fridge does not work after power outage
May be its board or board components got shorted.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Koolatron Mini Fridge Compact Refrigerator
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
We have a 25.4 cubic Whirlpool side-by-side fridge/freezer stainless steel look. Since the last 2 weeks....the display lights showing temperatures in fridge and freezer the front water/ice dispenser unit...
the clicking is from the lamp relay which makes the lights flicker and its located on the units rear area in the back,without a model number i cant tell what this boards model number is but you need to replace this whole board as they are non repairable(this is usually caused by a power surge or outage,which can destroy these boards,also even if a lamp in the unit burns out this can destroy this board too)
Mar 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Our Zanussi fridge is frost free type. Last week, the thick ice on the fresh food section of fridge (upper part) was melted by itself and leak the water everywhere. After we cleaned it out, the fresh...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Zanussi ZEBF250W Bottom Freezer...
My GE side by side fridge doesn't dispense water.
When you press the handle, do you hear/feel a click?
Is this just starting to happen after a power outage?
Is the ice machine making ice? Dispensing?
Do you have/know how to use a multimeter to check voltages at the water valve solenoid?
Thanks!
Feb 21, 2010 | GE (ESS25KSTSS) Side by Side Refrigerator
Icemaker dont work after power outage
Make sure the ice bail wire is not lifted. If it is, the ice maker will not make ice.
The water valve may have failed to. It's in the bottom back of the refrigerator, and the water line normally connects near where the valve is.
Let me know what you find.
Jan 30, 2009 | Refrigerators
Fridge only cools to 55 deg F
check the bottom of Ref. see if it close right, sometimes the rubber near the bottom parts broken.
Jul 08, 2008 | KitchenAid KSRS25IL Side by Side...
Ge profile arctica
It is unlikely that a power outage by itself will cause your problem. Recheck hour refrigerator thermostat. It should regulate to 38-42 degrees F. You can take an outdoor thermometer and put it into the fridge compartment, leave it for an hour or two and check. Adjust as necessary. If that doesn't fix it, we can proceed further.
Jan 23, 2008 | GE Profile PFS22 33" Artica French Door...
Whirlpool Side by Side Fridge Not Cooling
Here's the sequence: First, the unit must be ice free. This happens after power down for about 2 days. If the compressor is clicking, power off for 15 minutes. While waiting....
Clean the condenser coils.
If a mechanical thermostat, does it click when you turn it from off?
Locate compressor in back of unit. Find largest pipe. Power on.
Pipe should frost over for about a minute and then either dry out or form ice on it. If frost stays, you need refrigerant.
If compressor is not running, it could be thermostat, defrost timer (find this little gem in the back of the refrigerator and turn the stub shaft about 1/3 way around...does this change anything?) If the timer is bad...replace it.
Compressors generally don't fail from long run cycles.
hope all this gets you somewhere.
Nov 18, 2007 | Whirlpool GS6NBEXR Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
123 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
