Question about Lexmark X6170 All-In-One InkJet Printer
Need printer cartridges order number - Lexmark X6170 All-In-One InkJet Printer
I need new cartridges for this model but don't know the number to reorder.
the cartridge number is in the side of the cartridge
for example --cartridge 61xL
it can be genuine hp 61 or generic 61 but it is a 61 cartridge
the xl only means that it has more ink than a 61 or 61L
so look on the side of the cartridge and that is what you will need to order
Nov 03, 2016 | Office Equipment & Supplies
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Need to change ink cartridge
First you must identify which model Epson printer you have by going here.
You can either select your printer from the list, or enter the model number.
Once you have found your printer, it will tell you the model ink cartridges it requires, and even where to buy them.
We will need to know the model number of the Epson printer to be able to assist with the actual process of installation, as it can vary between printers.
Dec 08, 2009 | Epson Office Equipment & Supplies
What lexmark ink cartridge is the same as Dell Series 7 ink?
The best way to get series 7 cartridge is to either order online or order with dell over the phone. 18006249896
Jul 15, 2009 | Dell 924 All-in-One InkJet Printer
I need to order a new color cartridge door latch. where do i find one?
Here is the part number you need.
Link below where you can order.
C4557-60046
Cartridge latch (Color) - Holds color ink cartridge in place
http://www.feedroller.com
Dec 14, 2008 | HP PSC 500 All-In-One Printer
Epson photo r200
Sadly, if only one cartridge is empty, an Epson printer won't print. But, you can bypass that by using a chip re-setter. They have them in refill stores. By using a chip re-setter, you assign a new serial number to your cartridge, thus "fooling" the printer you have put a new cartridge in. Then, you don't need to refill all the cartridges.
Sep 09, 2008 | Epson Stylus Photo R200 InkJet Printer
Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
I own an x4550 what number ink cartridges do I need to order?
Here are the part numbers for the ink cartridges:
Cartridge Compatibility Black: 23(4), 23A, 34 High Yield
Color: 24(4), 24A, 35 High Yield
Apr 17, 2008 | Office Equipment & Supplies
Lexmark X6170 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
