Question about Brother Sewing Machines
Uneven stitching from bobbin
I have an older machine, a Brother VX-808, and I am having problems
with the bobbin thread making uneven stitches on the underneath of
the fabric. Some of the stitches look as if they are pulled out, and non are uniform in size. I tried adjusting the tension settings on the machine, but
I have misplaced the manual and am not sure of the correct settings.
Your help would be greatly appreciated.
Peggy Reyna
  • Anonymous Mar 16, 2014
    stitches uneven, threads not connecting
  • Anonymous Mar 26, 2014
    The thread doesn't come out properly from the bobbin its gets jammed up uneven stitching
Hi there!
Well you're right it's a tension problem.
Sounds like there is little or no tension on the top thread.
You probably have thread stuck in your tension discs. If so, set the tension at zero, open the discs with a small screw driver and blow between them. Sometimes you have to dig it out with tweezers.
Then reset clockwise untill you can feel the tension on the thread when you pull through it. It should be about the same as pulling a mug of tee along a table. (not specific I know - but you get the idea - and I love the tea!)
Hope this helps you.
Richie.
Posted on Jun 17, 2008
My pfaff2044 started sewing uneven stitches. It can sew nice then next second leave a big stretch then sew normal again and then itll leave a bigger stretch it also wont blind stitch.
3 Common Sewing Machine Problems (and How to Fix Them)
www.marthastewart.com/.../common-sewing-machine-rep...
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
sewingschool.org/2011/03/16/basic-sewing-machine-troubleshooting/
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven - SewingSupport.com
www.sewingsupport.com/sewing.../sewingsupport.../sewing.../my-stitches...
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
Dec 12, 2015 | Sewing Machines
Why is the bobbin thread looping and catching on my sewing machine? The stitches are uneven, too.
Hi Sylvia,
Your problem is an un-matched tension of the threads. You mentioned doing an adjustment recently. That is the problem area.
If your bobbin thread develops loops on the top side of the fabric, you need to tighten the bobbin tension.
There is no easy method for this and you will have to do it slowly -
tighten, test, re-tighten, test.... until you get a near perfect stitch.
I haven't come across a portable device specifically designed to set thread tensions.
Oct 08, 2014 | Dual Sew 3400 Mechanical Sewing Machine
Uneven feed
machines can have single or double feeders. what type does yours have? feeding problems can usually be fixed by a good cleaning+ oiling of the feeder mechanism which regularly gets clogged with lint+threads/scrap threads. brush it out thoroughly with a stiff-bristled brush like an acid brush. apply 1 drop of oil to each feeder seen on the foot-plate. wipe excess oil off with a clean dry rag being sure not to get any debris from the rag caught in the feeder(s). other problem might be your bobbin tension. this is usually adjusted on the bobbin race with a very small screwdriver.
Feb 22, 2014 | Brother PC-420
I can't form any stitch on my brother 3d - they are all loose and long and uneven. Do you know how to fix this please?
try changing the needle
try adjusting the top thread tension to 3 or 4
rethread the machine top & bobbin
make sure the bobbin is inserted correctly
& also wound correctly
Aug 05, 2012 | Brother Sewing Machines
When I am sewing it the fabric is getting pulled into the machine, and the bottom stitching is all uneven.
hold your top and bobbin thread for at least 5 stitches, and that the machine is threaded right.
Sep 05, 2010 | Singer 7462 Mechanical Sewing Machine
Brother VX 1120.... Machine is not making consistent stitches then thread loops and stitch goes straight and half zigzag, thread breaks. Same with straight stitches...will go for about an inch then stitch...
Remove the needle plate, bobbin case and bobbin and clean any lint that has accumulated.
Oil, if the manual indicates you should do this and where it should be done. Some do not as it has to be done by a repair tech.
Re-thread the machine with the presser foot in the up position.
Make sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
If the problem continues, the machine will have to be services by a sewing machine repair person. Take samples of the stitching so they can see what it happening - it could be the timing has to be reset.
Feb 16, 2010 | Brother Sewing Machines
Why is my machine skipping stitches
this is caused by uneven winding of the bobbin, sometimes the spool of thread winds unevenly when it travels up and down the spool. the best solution i have found is to use small spools of thread when winding the bobbins
Dec 02, 2009 | Kenmore 15516 Mechanical Sewing Machine
Tension problems
Possibly you have the bobbin in upside down and its turning the wrong way. Read manual. If you have done everything the manual says then it must be a mechanical issue such as the small thread take up spring or maybe the tensioner discs are dirty. Timing slightly off or there is a burr on the hook that catches the thread. Have a tech look at it.
Feb 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Ls1217 Brother
It sounds like you may have uneven tension between the bobbin thread and the upper thread. You can adjust the tension via a screw on the bobbin case. Turn it clockwise to tighten the bobbin thread tension and counter clockwise to reduce it. It's also worth remembering to check the tension on the presser foot for the material you are using. Check also that the shuttle race is clear of lint etc. Hope this helps
Jul 02, 2007 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
477 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
