Question about Kenmore Dryers
My dryer model# 417.91702000 tumbler is making a scraping sound. Looking from the top down shows a little sparking from a coil, seems to be scraping against the tumbler. Is there a easy solution to this?
  • 347 Answers
Depends on what you would consider easy. The issue you are having is with the rear bearing and bearing support.Replacement of these requires removing the drum assembly After unplugging the unit remove the top panel,then remove the front panel, remove the belt remembering how it goes around the idler, then the drum is free to come out do so by pulling up slightly on the back of the drum to release from the bearing then remove drum. Replace the rear bearing support in the back of the unit,and the bearing (ball) that's attached to the back of the drum. The bearing support and ball come as a kit or can be bought separate get the kit,also make sure it comes with or buy separately the special high temp grease that is used when reassembling the rear bearing. All this sounds like a lot but once you get started is not really that tough is just sounds like a lot when you are writing it all down...Good Luck
Posted on Nov 11, 2010
When turned on dryer tumbler makes a metal on metal scraping sound?
Most dryers glide on felt. Either the felt has worn out (not very likely) or something has gotten between the drum and the felt. Could be anything from loose change to jewelry...anything that made it into the dryer from a pocket
Feb 13, 2016 | Dryers
Model #: GE DRSR495EGWOWW metal on metal scraping sound bottom of drum top of lower lip, near blower motor. Cannot seem to identify exactly what is causing this. Things I have done: replace the glide...
check the felt strip,i've found screws,pennies,nuts and bolts stuck into the felt strip or the blower wheel is scraping,usually it's the rear gearing,the sleeve wears down part number WE1M462 and it's like 12 dollars
Apr 24, 2011 | GE Dryers
Dryer makes banging sound as drum rotates
The drum rollers are worn out and wobble when moving..it should be more of a thump/thump sound, unless really are almost gone...UNPLUG dryer and raise top...Since no model. i'm going with standard kenmore/whirlpool dryer type. The top has two screws by lint filter..Remove these and raise top...The front can be removed by removing two screws inside each front corner. The door switch must be disconnected at wiring..Remove front and set aside...The drum can be removed after the belt comes off...look down in right rear corner under drum..you will see the belt pulley and you want to see how it goes around pulley to help reinstall..remove belt, there will be tension and make sure you draw yourself a diagram of path of belt to ease install of belt....now once belt is removed, you can pull out drum...there are two drum rollers. They are bad if you roll them and they wobble and make noise. They should be almost quiet when you roll them if they are good..the belt roller can be bad and squeek...check this as well...replace parts and reinstall
Jan 31, 2011 | Dryers
Roper elctric dryer model RES7648EQ make grinding and scraping noise when i start it. Found a bra hook cought in drum on inside of dryer took it out now when I started it it smelled like the belt was...
belts dont really burn the main reason for buring smell is lint on the element did you take the whole barrel out? as 90% of the lint that burns is formed around the heating coil behind the barrel
best of luck sir
Dec 02, 2010 | Roper RES7648E Dryer
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My dryer (neptune original series) is making a scraping sound. The last time this happened, the bolts that hold the tumbler in place were loose and rubbing against the top of the dryer. I need to know how...
first take out the 2 hinge screws then the other 2 across from the hinge pull the panel down. then you will see a 5/16 screw holding a hook that is holding the top down. there is one on each side. let me know what u find.
Jan 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Loud Grinding noise in Dryer
I know this prob is old, but I had the very same prob with my dryer (very loud squeaking noise). The prob was that there was a screw stuck between the rotating part and the stationary part. Meaning - look inside the dryer (main area - where the clothes go) and rotate it by hand. You may hear and see something causing the friction. Gerard
Dec 29, 2008 | GE DSXH47EGWW Electric Dryer
Scraping sound on left side as it goes around
You need to replace the tumbler guide rubber wheel. I would suggest to avoid further issues, replace all base guides.
It requires dismantling the Dryer.
e
Dec 17, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Scraping noise
hi there,
the scraping could be the tumbler itself. please check the belt around the tumber and make sure that it's not worn.
thanks
Sep 29, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is shooting sparks and making a scraping sound
hoover washer drier is making a scraping noise and a spark from the bottom of the machine everytime the drum spins, does anyone know what this cold be. thanks.
Apr 05, 2008 | Kenmore 83142 Electric Dryer
Dryers Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
