Question about Rowenta DG5030 Iron
Steam trigger broke
The steam trigfer is broke where do I get a new one?
  • katemo Feb 23, 2009
    My DG5030's soleplate is getting hot and the water pot is steaming, but the trigger button doesn't click, nor does steam come out of the soleplate holes. The fat cord does not get warm either.
    Scholar:
  • 65 Answers
I did some research for you and i found out the main web for Rowenta Usa and they do provide spare part as well.
You can also send the iron to a repair center near to you if under the warranty at no cost.
This is the information i got from them
http://www.rowentausa.com/rowenta/frame.aspx
Good Luck
Posted on Jun 19, 2008
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Steam button broke?
I've looked up parts for this iron. Sorry to say the steam button is not listed. The button may be able to be repaired at a small apliance repair center, but I do not know what the cost would.
May 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
Ssteams constantly without pressing steam trigger
Sounds like your trigger valve in the iron portion (not the tank) is jammed open. It could be from mineral deposits so maybe try running it with a solution of distilled water and a couple of tablespoons of vinegar in the tank. Wiggle the steam trigger to try to release any scaling that maybe present inside the valve. If your steaming from the iron stops, you've fixed the problem so let the iron cool and rinse the tank using ONLY DISTILLED WATER which anyone knows is the only type of water to be used in ALL appliances. Minerals in regular tap water kill appliances quickly. Never use tap or bottled drinking water even if the directions say it's okay. Iron some old rags or towels with a tank of distilled water to make sure no mineral deposits or staining steam comes out after cleaning.
If this fix doesn't work, you can buy a replacement iron portion online..try 1800Parts.com. It's cheaper than buying a whole new iron but you may need a repairman...I've never tried to fix this portion of my DG5030 iron.
Aug 28, 2013 | Rowenta DG5030 Iron
Shoots out through the steam vents and sains clothing
The symptoms you describe are indicative of mineral buildup in your iron. The instructions probably say to use distilled water in the iron and may include a procedure for removing mineral deposits
Jan 14, 2013 | Rowenta DG-980 Iron
Won't steam
I know it's a silly question but are you pressing the trigger in the handle? If you are then the solenoid valve may have failed
Nov 20, 2009 | Rowenta Steam Generator DG050 Iron
Need new water tank for vin067
where can I buy Breville steam iron parts (vin067) as the steam button has broke. Please help!!!
Aug 31, 2009 | Irons
Morphy richards steam generator model 42271
is there a noise when u press the trigger? if not there is sometimes a reset button on the front of the base. failing that the problem may well be the solenoid which opens to let the water into the steaming tank which is repairable but can be awkward.
Feb 01, 2009 | Irons
Rowenta DG5030 Iron Logo
422 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
