Question about Poulan Pe550 Gas Edger
Why does my primer bulb when pushed stay push in and won't retract? PE550 Weed Eater Carburator?
    President:
  • Poulan Master
  • 1,545 Answers
You may have a clogged in tank fuel filter, lines in the tank broken off of the fuel filter and line fragments clogging the fuel lines. . Fuel lines get flaky when they deteriorate. Your primer bulb may be leaking also. The check valves in the carburetor control the flow of fuel in and out of the primer bulb. The carb may need cleaning. In other words, a complete fuel system assembly inspection will be needed. If the bulb is on the carb, the check valves in the base assembly below it may be sticking. Remove bulb and spray in there with WD-40 to free frozen or sticking check valves. The valves are very small and malfunction occasionally
Start your inspection at the fuel tank and work your way to the carb. Pull the cover off the carb on the end opposite the end with the vent hole in the cover. You will be pulling off the fuel pump cover. Inside the carb body you will find a very small round fine mesh screen. Clean it well with carb cleaner and when you reassemble, spray some WD-40 in that area too.
Posted on Nov 11, 2010
I have a PE550 Weed Eater Edger and have new carb, new fuel lines, new ignition module, new gas filter, new gaskets, and new air filter.... and it still won't start, what should I do now?
Theres a screw for gas and air mixture on it you need to turn it all the way in then turn it 1 and a half times out , its a perfect factory setting the push primer 3x and turn on choke pull 2x then turn off choke should run hope this
Sep 28, 2013 | Health & Beauty
Weed Eater PE550 711431, new primer bulb will not pop back after second second push.
FIXED- No start Weed Eater with the symptom of the primer bulb collapsed, not filling nor returning to pop out after pressed.
Worked in model WT-3100 with Walbro carburetor WT-583 and has to work in many others. It happened after winter hibernation, even when left with no fuel to prevent formation of fuel deposits.
FIRST, mark/scribe the carburetor fuel outlet that has the hose towards the primer purge bulb as 'OUT' and the fuel inlet coming from the fuel tank 'IN'
The problem was a fine mesh metal screen strainer blocked by contaminants, inserted at place shown as number '3' in figure 7 at
----> www.drystacked.com/Walbro%20Carburetor%20Theory%2027Jun2010.pdf
That fine mesh was removed by prying its edges around with a sewing needle held by pliers.
It you cannot see light trough it holding it against a lamp, is blocked even if looks clean.
Removed, discarded, reassembled and started. Later ordered the part or kit but was able to use the machine immediately.
Writing this as am tired of seeing responses like 'may be this' or 'try that' or 'perhaps the other' by guessers.
Aug 07, 2013 | Poulan Garden
Repair weed eater
If you see gas in the primer bulb it is pulling in gas to the bulb. If not check for cracks in the bulb assembly and check to see if the fuel lines are not off their fittings and not cracked.
Jul 17, 2013 | Garden
I have a problem with an Echo-SRM 310
wrong primer bulb installed have to get right one this one not letting fuel come in
Nov 10, 2012 | Echo Garden
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Weed Eater Lightweight 1500 Leaf Blower Fuel Line Repair. There is something in my gas tank, which I assume is a filter of some sort and I need help getting one replaced and onto which fuel line it should...
there are two lines going into the tank one is short which just goes in the for pressure from the primer bulb the other line goes to the filter which goes to the carburator
Itsman
Nov 03, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
How to hook up a carburator on a weedeater with a primer bulb
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 18, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I I need the little plastic gas plunger for a Poulan Featherlite Plus weed eater
The part is called a primer bulb if it is mounted on the carburator or if it is a remote primer it is called a primer pump. Check with a full service dealer in your area if you have one. If you
can not find one in your area contact southern supply company at
205-833-2525 or email them at southern.supply@mindspring.com
and I feel sure Jason or someone there can help you.
Sep 13, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Took tank off weed eater and not sure how the lines go back on
The line with the fuel filter in the end comes out of the tank and it goes to the bottom fitting on the carburator. The other line comes out of the tank and goes to the bottom fitting on the primer bulb, and the third section goes from the top fitting on primer bulb to top fitting on carburator. Got it? lol Hope this helped and best wishes.
Aug 19, 2009 | Garden
Poulan Pe550 Gas Edger Logo
915 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
