Question about Microsoft Xbox 360 Console
Whats is 1 red ring on xbox360 - Microsoft Xbox 360 Console
    New Friend:
    Problem Solver:
  • 7 Answers
Your Xbox hard drive is over heating and you need to get either a new hard drive or a new Xbox
Posted on Feb 11, 2014
    Sergeant:
  • 415 Answers
It is most likely your AV. Unplug power to power supply and Xbox and un plug AV cord. Let it sit for 15 Minutes and the plug everything back up and see if that corrects the problem if that doesnt repair problem google xbox360RROD... or search what do the red lights on Xbox 360 mean. Keep searching you will find what you are looking for eventually.
Posted on Nov 12, 2010
4 Suggested Answers
Raheeeeb
  • 20 Answers
SOURCE: 3 red rings
yes over heating best to go microsoft care point or support online at x-box site and see what your nearest service point. -my self ,i use to fix two fans one to increase the cooling system and one to brought out the heat, all most the solution care about increase the cooling factor, but they always ignoring that the heat should be go out. by this you can play most of games and operate your x-box as long you want . -some of x-box board components might affected by been heated and cooling in normal operating so this case you should reflow the GPU and CPU. Nothing safe than use jovy RE-7500 to make this process .
Posted on Sep 05, 2007
SOURCE: xbox360 rings of death.
If you only have two red lights that means your xbox is overheated I had this trouble and took mine out to the air compresser and blew massive dust out of it,It's been 2 months now no lights.
Posted on Mar 08, 2009
SOURCE: one flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Posted on Sep 15, 2009
My xbox360 goes on red ring when i play it
there are many different kind of "red rings"
If they are all red, it means that your av cable isnt being detected
if there are 3 red, its a hardware failure
2 means that your system is overheating
For more information, check out this: http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Good luck, if I helped you, please give me a positive review :)
May 26, 2011 | Video Game Consoles & Games
My xbox 360 freezes after being on for a couple of minutes. How do i stop this
If it freezes and then the next time you turn it on has red lights on the console display check out the corresponding Microsoft articles for the number of red rings on the display. They appear in quadrants on it.
1 red ring
2 red rings
3 red rings
4 red rings
If you do not have any rings, your console may just be overheating. Give it a while to cool down and if that doesn't work, give Microsoft a call: 1-800-4MYXBOX. Good Luck!
Jan 05, 2010 | Microsoft Xbox 360 Console
Red ring on xbox 360 how do i fix it
Commonly known as ' Red Ring of Death '. Unfixable and Uncontrollable :(
Follow the below steps :-
Step 1: Swear a lot
Step 2: Call 1-800-4MYXBOX (Or 1-800-469-9269)
Step 3: You're going to start hearing a guy named "Max" talk to you, he's just a computer, just keep repeating the phrase "Agent" over and over again, it's a keyword that you don't find out unless you've called before, it directs you to a real person.
Step 3.5: If "Max" asks what console you're talking about, answer "Xbox 360"
Step 4: Tell the agent (Who will probably ask for your name first) that your Xbox360 got the three red rings of death (Mention three red rings, not just "red rings")
Step 5: At this point the person will most likely ask you to run some tests, they'll ask you to try running the xbox360 with the hard drive not attached, and then they'll ask you other stuff like what color the power cord box is, etc. etc. This is to see if your hard drive, power cable, or the xbox itself has a problem so it's not useless, just be wait it out
Step 6: They'll ask you for some billing things and just answer where you want to get the package, they'll also give you a reference number
Step 7: (This takes 3-5 days:) They'll send you a box with some foam, plastic, and sticky tape for packages.
Step 8: Get a label and stick the reference number they gave you on your xbox
Step 9: Put your xbox in the plastic that comes with it, and then put the foam things on
Step 10: Put the 360 in the box (It's prepaid) and then close it up using the tape they gave you
Step 11: Use the sticky tape you got to close the box again, then go to the post office and send it out to the return address that's on there.
Step 12: Wait 3-5 Weeks
Step 13: You should get a new xbox360 within that time
If the box takes longer than 5 days, or your xbox takes longer then 5 weeks, call them again and mention you're reference #
Thanks.
Sep 01, 2009 | Microsoft Xbox 360 Console
Xbox360 e74 error
Section 4 is flashing red
- Hardware Failure
Jun 06, 2009 | Microsoft Xbox 360 Console
Rings of death
the "3 rings of death" or the so called "3 red lights" is actually caused by GPU overheating and mainboard flexing. When you need to do is open your xbox360 (warning, this will void your warranty) add more cooling fan inside your xbox360, you'd want to use 80mm fans coz they fit perfectly. you can fit up to two 80mm fans inside your xbox360.
Also, if you notice that your xbox360's mainboard is warped you need to fix this by disconnecting all the connections from the board. then place the board on a flat surface. then use a hair drier to heat the board and flat it out. its kinda complicated. hehe, at least you now have an idea on whats causing the 3 red lights...
May 01, 2009 | Microsoft Video Game Consoles & Games
Xbox 360 3-red lights may be caused by DVD drive? Help please!
your 360 is a first run off assembly. they were junk from the start. my warranty expired also but called microsoft and they said if the ring of death is related to the first run of 360s they willextend the warranty. exactly what happened to me. 8 days later they sent me a brand new 360 cause problems with the first run 360s can't be properly fixed. contact them tell them the problem and you will get a new one. hope this helps Tadster
Apr 15, 2009 | Microsoft Xbox 360 Console
Xbox360 rings of death red rings when i turn on the console. can you help?
Jan 07, 2009 | Microsoft Xbox 360 Console
Xbox360
all u have to do is ring up the support number and tell them your xbox is broken and they will pick it up and a week later it will be back with a free 1 month xbox live and a free face plate i red it in a magazin
Jul 20, 2008 | Sega The Club - Xbox360 for XBox 360
The green ring of light on my xbox360 keeps going to red
how many red rings do you get is it red ring of death with only 3 lit or what?
Jul 02, 2008 | Video Game Consoles & Games
Xbox360
ring of death microsoft should replace it, take it where you bought it or send it back, call first and tell them its the ring of death.
Oct 18, 2007 | Computers & Internet
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
