Question about General Electric Microwave Oven
I have a GE Microwave M/N JES737WM02 that is now reading PF instead of a numeric display...What does PF mean?
  • mzpattic981 Nov 11, 2010
    Never mind....I just googled it...I knew it meant Power Failure but I didn't actually hit the "clear" button to reset the unit...I only unplugged...thanks anyways.
What does "PF" error message mean?
It means power failure. The power might have gone off in your house. Try resetting the clock.
Aug 31, 2013 | General Electric Microwave Oven
Ge mircowave message is P F
"PF" means that the power has been interrupted, so you need to set the clock, then the oven should work.
If you actually do have a problem with this oven, it will have to be replaced, since GE does not make repair parts available for it.
Jan 16, 2013 | GE Microwave Ovens
I have a GE microwave model# jes737wm02 manufactured inFeb. 2009 it runs but won't cook
we purchased a ge microwave about 2 yrs ago & the paint is peeling on the inside. Is this dangerous & should we continue to use it?
Oct 28, 2010 | GE JES738 Microwave Oven
Got code PF and control keypads not working?
Hello :
PF indicates power failure . Displays this message after it has been unplugged or if there has in fact been a power failure .
good luck .
please rate !
Apr 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Key pad lockout and load beeps
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
Since it's a basic counter top microwave, this may not be worth repair when you consider the cost of a new comparable unit.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
The part number of your keypad is
WB27X10624 and you can get it here for $51.37 plus shipping.
Dec 27, 2009 | GE Countertop Microwave Oven
My GE microwave started running by it's self. It first said 3.5oz and would not stop until door was opened. then it started beeping and wouldn't stop until door was opened. we unplug hoping it would reset...
It sounds as if you key pad is sticking. PF means that there is an input power problem but could be caused by the sticking keypad.. As far as the unit starting bu itself, the only thing that can cause that is the keypad.. Try running your fingers flat across the panel several times both vertically and horizontally and see if the pad malfunction clears. It will probably repeat in the future but you could get lucky and have a one time instance. The keypad itself is just a bit over $75.00 if it has failed. Good luck.
Dec 10, 2009 | GE JVM1440 Microwave Oven
Ge spacemaker microwave when i plug it in comes up with PF on the screen and does not work at all,it has power and the light inside is on,i can press the 3 minute button and the microwave will wor but that...
ther should be instrustions manual sound like mocro is working suspect control panel it needs 2 be reset how read manul panosonic push stop 1 at same time menu comes up push reset this is a minor problem hopes this help u
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
PF ?
Not actually dead, just apparently unresponsive.
PF means power failure. It either got reset or unplugged, etc.
If it's not responding to the keys, then you likely have a shorted keypad or trouble on the control board.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 25, 2007 | GE JES1238 Microwave Oven
General Electric Microwave Oven Logo
147 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
