Question about Baby Trend Travel System - Orange Oak Stroller
I just need help on removing the wheels, I was told to remove the wheels before I send it in for service.
    Guru:
  • 541 Answers
You'll find your manual here.
www.babytrend.com/product_manuals_2.html
Posted on Nov 12, 2010
Maytag neptune mde5500ayw chirping, buttons wont do anything. was told to replace control board. that did'nt help at all. any ideas?
The blower wheel on these tends to wallow out. That makes the dryer overheat and take twice as long to dry the clothes. Lint begins to build up in the filter housing. Finally the temp exceeds 350 and the round white fuse on the blower housing melts. Boom you has got a dead dryer. To get into the slopefront type dryer seems a bit intimidating bit really is not. Remove the door. The door is reverseable so 2 more screws opposide need to also be removed. Then the goalpost shaped front pops off. Then that reveals the top hold down straps. Remove them and top can be popped. Next you remove the front shroud the drum rides on. then get the drum out. Did I mention you do not work from the back at all on this model? Do not try to fix it in the wash room. Take it ouitside and put it on the picnic table or a tailgate to repair it. You will need a phillips head screwdrivers pliers 1/4 and 5/16 nutdriver and snapring pliers.
Shopvac to clean it up and probbaly a new fuse and blower wheel.
SERVICE MANUAL
Jul 31, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Remove steering wheel from Sportcraft center console boat
Is your steering using the cable / pulley and springs, or has it the through the tube steering? If it's the later, undo the nut that holds the cable to the transom bracket, Then try and turn the motor, If the motor won't budge, the pivot is seized, If the motor moves, your cable is seized or the steering box needs help! How to remove your steering wheel, There will be a cover hiding the nut in the centre of the wheel!
Feb 15, 2012 | Boating
I need to take the steering wheel off the Nissan Quest 2007
I'm guessing you need instructions on how to remove it. Below are instructions and diagrams from my service manual for you. These pictures were the biggest I was able to put on here due to a size limit. The first set is how to remove the steering wheel but the air bag needs to be removed but instructions on how to do that is below as well including the direct connect ofr the wiring harness. If you cannot see it and need it bigger or if you have any questions feel free to email me and I can send bigger pictures or try my best to answer any questions you may have. My email is csautomotivecars@att.net. I hope this helps and was what you were needing. Goods luck
Jul 21, 2011 | 1997 Nissan Quest
2006 xc70 140k .I am told the all wheel drive pump needs replacing and they are unable to remove it from the casing. They are suggeting removing the entire differential and sending to a machine shop???...
Why would a machine shop have any interest in
Motor Vehicle Parts?
I think your at the wrong shop
Hopefully not a dealer telling you that
Something wrong with that story
Do some research on the internet or go
to a dealer & walk into the service bay
from outside & talk to a tech about the issue
If your at a dealer, go to different one for info
Jun 29, 2011 | 2006 Volvo XC70
How do you remove the front wheel bearings?
email me at iambanshee74@yahoo.com and I can send you the removal instructions. These units are not serviceable and will require the replacement of the hub assembly but I can send you the instructions to do so.
Oct 23, 2010 | 1998 Isuzu Rodeo
How to replace rear wheel bearings
don't have topaz. maybe escort will help guide you.
Section 04-02: Suspension and Wheel Hubs, Rear 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Wheel Bearing and Hub Assembly NOTE: Wheel bearings are not serviceable and should therefore be replaced as an assembly with the wheel hub (1104).
Removal
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
  1. Remove the hub grease cap (1131) from the wheel hub.
  1. If equipped with disc brakes, remove the rear disc brake caliper (2552) and rear disc brake rotor (2C026). Refer to Section 06-04 for the removal procedure.
  1. If equipped with drum brakes, remove the two brake drum screws and the brake drum (1126).
  1. Unstake the rear axle wheel hub retainer (4B477) securing the wheel hub to the rear wheel spindle (4A013). Remove and discard the rear axle wheel hub retainer.
  2. Remove the wheel hub from the rear wheel spindle.
Feb 06, 2010 | 1990 Mercury Topaz
Front wheel barring
They are not too bad if the bearing/hub assy is not frozen into the aluminum steering knuckle.They are held in with 3 13mm bolts from the back side.Remove the front wheel on the side in question,remove the brake caliper,brake bridge,pads,remove the axle nut 36mm(big socket required here)once you have all this removed remove the 3 13mm bolts tha retain the hub/bearing to the steering knuckle by hammering downward on the hub,don't worry if you tear it up come with new one.If you dont see it coming apart after 10-15 blows with a large hammer it maybe siezed up.Then you will need to hit alot hard or heat the knuckle.But be carefull the knuckle is aluminum.hope this helps
May 21, 2009 | 2003 Saturn VUE
I can't remove back wheels on a baby jogger 2 buggy HELP!
There are metal clips near the back wheels that go around the black plastic "axle" piece of the stroller. Squeeze the clip to the far side of the axle and the wheels will easily come off.
Apr 27, 2009 | Baby Jogger 2 Stroller
Baby Trend Travel System - Orange Oak Stroller Logo
51 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
