Question about HP LaserJet 3600n Printer
The printer makes a clicking sound when it is turn on, Sounds like one of the plastic gears is slipping? Thanks, Brad
    Genius:
  • 1,570 Answers
It heard that sound before our HP laserjet model. The reason maybe is that the roller plastic drum was torn off due to volume printing. This needs technician to replace that parts and it is replaceable. Most of them are torn because of heat emitted by the printer.
Posted on Nov 11, 2010
I have Brother MFC 7820N printer. It has a loud clicking sound on the left rear end and paper will not feed, sometimes the first page will print and no paper message will be shown? Can you please help
It sounds like a displaced drive gear in the gear chain to the fuser. If you remove the covers and the fuser unit you should be able to manually turn the gears to check for jams or slips. Make sure all ther gears are correctly seated and no missing teeth.
May 19, 2014 | Brother MFC7820 ALL IN ONE LASER PRINTER...
Xerox 6330 loud clicking sound
Check the rails the paper tray sits upon. see if the one on the right side is damaged or dislodged. You didn't say if the noise happened when you printed from the 2nd paper tray.
Apr 01, 2014 | Xerox Phaser 6360 Laser Printer
Subzero 690 ss icemaker making a clicking sound why
If the noise is coming from the ice maker head itself. Then it sounds like the gear is slipping. They are plastic and it is very common for them to crack or break. Most ice makers are the same. Click Here to see a post on a Whirlpool ice maker with a broken gear.
Good Luck From David at refrigerator repair.
Apr 04, 2013 | Refrigerators
1994 ranger wiper not working, just making a clicking noise
check the wiper motor gears. sounds like its slipping, may be a plastic gear
Dec 15, 2012 | 1987 Ford Ranger
Hp 4L printer won't pickup paper from tray. Sequence- green led light- motor running but with grinding- no movement from pickup roller or foot- finally a misfeed led light.
That is a very common problem with the Laserjet 4L and 4P printers. The sound you hear is caused by a broken motor drive gear. This is a small plastic gear on the drive motor shaft. They can develop a small crack which prevents the motor from turning the gears for paper pickup and toner movement. When the motor tries to turn the broken gear can not turn the other gears and makes the popping or grinding sound when the gear teeth slip. You will need to replace the motor gear, it is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
I hope this helps,
BuddyMc
Jul 16, 2012 | HP Office Equipment & Supplies
Why is my samsung clp making a clicking noise?
Is the printer making a clicking sound when it is printing? Or is it just making a clicking sound but there are no light and the printer appears to be dead except making a clicking sound?
I know of a cause for either case.
Case 1. It is clicking when printing. Sometimes the toner cartridges are not seated properly in the imaging unit, and causes the gear on the cartridge to slip making a clicking sound as the gear is being turned. Try pulling out the cartridges and try turning the gear. It should turn smoothly without binding. If it binds, there is not much you can do about it except replace it when it goes empty. Reinsert the cartridge and check that it inserted completely into the imaging unit.
Case 2. Printer is dead, not printing except making a clicking sound. This is due to the power supply board failure. Usually the failure is due to a blown filter capacitor on the power supply board. The power supply is located on the right side of the printer. Remove the right side panel to get access to the board. The board can be either repaired or replaced. Hope this helps you.
Feb 22, 2011 | Samsung CLP 300 Laser Printer
Before pulling in paper printer makes a gear slipping noise. sounds like plastic gears slipping. printer works ok otherwise
One of the gear in the roller mechanism is either displaced and not in alignment with other gear wheels OR the gear blades is broken. You have to take the assistance of technician from service center to open the printer and change the part. You can not do it your self.
Sep 15, 2010 | Office Equipment & Supplies
Weird problem - printer works fine but noisy; sounds like gears are slipping. Afraid that it won't last much longer.
Noise is not good. The gears are plastic so they are self lubricating and quiet.
Open it up and check for any obstructions or excess dirt. That may be causeing the gears to bind a bit.
Unforuntetly the gears will eventually break if they are binding and making noise. At that point you should just replace the printer (if not before) as it will not be cost effective to fix it.
Apr 07, 2010 | Brother HL 1440 Laser Printer
1998 Chrysler Cirrus LXI transmission sounds.
Tow it to a reputable transmission shop. Don't forget to check with your local BBB for complaints and get lots of quotes.
Sep 15, 2009 | 1995 Dodge Stratus
Gears?
sound like the fuser to me, remove cart and turn on, does it still make the noise? if so, it is the fuser if not there is a gear drive assy, check the gears
Nov 23, 2007 | HP LaserJet 4p Printer
HP LaserJet 3600n Printer Logo
318 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
