Question about Kodak MX1063 Digital Camera
My MX 1063 kodak camera will not turn on or charge. The charge light doesn't even come on
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Posted on Jan 26, 2009
  • 1632 Answers
SOURCE: blown sand in camera, blew out as much as i could.
You got to really clean it good. Probably the sand is in the lens extension preventing the lens to oppen. That is the problem.
Vitally
Posted on May 15, 2009
vortash
  • 431 Answers
SOURCE: camera will not turn on and battery is fully charged
Hi I am Vortash I know this might sound silly but check the battery is in the correct way round .. if your like me and changed the batteries to my easy share I forgot a couple of times and put them in the wrong way round ..( even we make mistakes ) reversersal of the batteries cured my problem and added to my embaressment lol .. other than that check the batteries havent leaked and if they have look in the battery compartment for signs of damage rust etc .. and if you are still using the easy share battery that came with the camera .. it might say it is charged but may not be mine was dead and wouldnt charge afyer about 6 months use .. Regards Vortash
Posted on May 17, 2009
leepania
  • 1099 Answers
SOURCE: i have kodak md 1063 camera . and i want to update
There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly.
An Out of Warranty repair for this model for this fault is about 48 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Jan 05, 2010
leepania
  • 1099 Answers
SOURCE: Our Kodak MX 1063 turns on but immediately turns
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Posted on Feb 08, 2010
Kodak mx 1063 how I charge from my pc,I have no separate charger
Yes, you may charge the battery by connecting the camera to a computer USB port. Bear in mind that not all computer USB ports supply enough current to charge the battery, however.
Nov 06, 2012 | Cameras
What kind of memory card should I use in my MX 1063 Kodak?
The M1063 uses SD and SDHC cards.
There are two main schools of thought on memory card size. One says get the biggest card you can afford so you can take as many pictures as possible without interruption. The other says get two or more smaller cards and switch among them so that if one card goes bad (or gets lost, or stepped upon, or...) you don't lose all your pictures.
As to brand, any of the major brands will work fine. With this camera you don't need to pay a premium for higher speed cards.
May 09, 2010 | Kodak MX1063 Digital Camera
My m863 kodak camera charging light won't turn on.
Is the camera charging? Remember when charging thought the computer NOT to switch the camera on since this will deactivate the model to charge. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EasyShare M863 Digital Camera
Have a kodak m1033 that seems to be frozen in the "off" mode. Have replaced the battery twice, works for a day or two then won't/can't charge and can't get the power light to come one even with the charger...
All Technical equiptment can have problems Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 19, 2009 | Kodak EasyShare M1033 Digital Camera
Hi, we just bought a new power cord for our camera and when we plug it in it blinks green once and red three times and then it doesn't charge. is there anything we can do to solve this problem? it is a...
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Oct 08, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak 1063 Not transferring all Pictures
Charge battery full
Then TAG the pictures with as many tags possible. Up to 10
Make new tags.
then Protect and Favourite the pictures videos etc.
Then transfer again to your "file" on computer. and check for the numbers are continius. Delete the dupl;icates that show with the 2 zeros "00"
Vitally
May 27, 2009 | Kodak EASYSHARE M1063 Digital Camera
Blown sand in camera, blew out as much as i could.
Vitally
May 14, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak MX1063 Digital Camera Logo
182 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
