LOW VOLTAGE WIRING CONNECTIONS BETWEEN NORDYNE FT4BF-0-36KA 16 SEER 3 TON HEAT PUMP AND B4VMX36KB\AH VAR 410A AND RITE TEMP 6036 THERMASTAT
  • 2 more comments
  • jga684 Nov 11, 2010
    ORIGIONAL QUESTION WAS, LOW VOLTAGE WIRING CONNECTIONS BETWEEN NORDYNE FT4BF-0-36KA 16 SEER 3 TON HEAT PUMP AND B4VMX36KB\AH VAR 410A AND RITE TEMP 6036 THERMASTAT.
    REPLY TO YOUR QUESTION; THERE ARE 8 WIRES COMING FROM THE OUTSIDE UNIT. THEY ARE Y, R, O, C, W2 IN, W2 OUT, Y2, L. THE TERMINALS ON THE AIR HANDLER AREC, R, G, Y/Y2, O, W1, W2, Y1. THE TERMINALS ON THE THERMOSTAT FOR TWO STAGE HEAT AND COOL ARE; C,B, O, W2, W1, Y1, Y2, RH, RC, G, A.
    WHAT HOOKS TO THE AIR HANDLER FROM THE HEAT PUMP AND WHAT HOOKS TO THE THERMOSTAT FROM THE AIR HANDLER?
  • jga684 Nov 12, 2010
    MY EMAIL IS JGA689@VERIZON.NET
    GORDON
    DO YOU HAVE A FAX NUMBER THAT I CAN SEND MY CONTROL LAYOUT? I DON'T THINK YOU ARE UNDERSTANDING MY QUESTION.
    GORDON
  • jga684 Nov 13, 2010
    ARE YOU FAMILIAR WITH THIS NORDYNE UNIT? FOLLOWING IS A DESCRIPTION OF WHAT I HAVE. LOW VOLTAGE WIRING CONNECTIONS BETWEEN NORDYNE MODEL FT4BF-0-36KA 16 SEER 3 TON HEAT PUMP AND NORDYNE B4VMX36KB\AH VAR 410A AIR HANDLER AND RITE TEMP 6036 THERMOSTAT. THE CONNECTIONS ON THE OUTSIDE UNIT ARE Y, R, O, C, W2IN, Y2, L, W2OUT. THE CONNECTIONS ON THE AIR HANDLER ARE Y1, W2, W1, O, Y/Y2, G, R, C. THE CONNECTIONS ON THE THERMOSTAT ARE C, B, O, W2, W1, Y1, Y2, RH, RC, G, A. WHAT TERMINALS FROM THE OUTSIDE UNIT CONNECT TO THE AIR HANDLER AND WHAT WIRES FROM THE AIR HANDLER CONNECT TO THE THERMOSTAT?ARE ANY OF THE TERMINALS ON EITHER THE AIR HANDLER OR THERMOSTAT JUMPERED TOGETHER. MY EMAIL IS JGA684@VERIZON.NET
    THANK YOU,
    GORDON
  • 8,220 Answers
I guess you have not had the satisfactory answer you has been seeking since I been seeing this question all day.It is not surprising.
What you have is a heat pump.
It uses a compressor to heat and cool
This isnot an ordinary system. the unit uses a solenoid to reverse the flow of freon and needs a defrost mode, plus it requires backup heat. AND all of the wiring config ain't the same my nizzle.
This is just my take on it from what i know. I sold thermostats before i retired. heat pumps need specialty thermostats to not only cover the reversing valve but the back up heat and defrost features as well. that is why you only use the recommended wall thermostat for a designed heat pump. I thank you.
Posted on Nov 14, 2010
    President:
  • 1,796 Answers
Hi!!
The Rite Temp thermostat can be wired many in ways according to your unit's needs, I would like to send you an installation guide showing the different configurations, then you tell me which and how many wires come from the heat pump and we go from there. For this I need an email address to send it to. Thanks
Posted on Nov 11, 2010
  • 3 more comments
  • Rene J Solis Nov 12, 2010
    Hi!
    Follow this steps to connect the thermostat for a 2 Stage Heat and Cool. To complete step 5 I need an email address to send the diagram to. This site does not allow us to send images larger than 150k
    STEP 1 - Connect the W wire to the W terminal and W2 to W2 on the 6030. This connects 2 stages of heat.
    STEP 2 - Connect the Y wire to the Y terminal and Y2 wire to Y2 on the 6030. This connects 2 stages of cool.
    STEP 3 - Connect the RH or R wire to the RH terminal on the thermostat. This connects the Heater/Cooler Power.
    STEP 4 - Connect the G wire to the G terminal on the Thermostat. This connects to the Fan.
    STEP 5 - Set Config jumpers per this diagram. If you have Electric heat set 4, if you have Gas or Oil set 5.
    Your HVAC system is now connected to the 6030.
    The C wire from the furnace provides power to the thermostat (terminal C) it is optional to connect it, I recommend to connect it since it will keep your batteries as a back up source of power thus prolonging battery life considerably.
    Hi Gordon, I tried to send you the file and I got the following message from gmail. Please verify the email address or send another one. Thanks
    MESSAGE:
    Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about the cause of this error. The error that the other server returned was: 550 550 5.1.1 unknown or illegal alias: JGA689@VERIZON.NET (state 14).
    Your file has been sent, I figured it out, you wrote 689 instead of 684.
    I don't, but you can send me a scanned copy to my email address. I have a question, are you trying to replace your old thermostat with the Rite Temp 6030? If so, what brand and model of thermostat do used to have?
Where are the heat strips on a rheem classic 10 seer heat pump
3 Ton Heat Pump Split System ' eBay
www.ebay.com/bhp/3-ton-heat-pump-split-system
eBayGoodman 3 Ton 14 SEER Heat Pump Split System GSZ140361 with Installation Kit.10k Heat Strip,Thermostat,Wiring, Disconnect Box,Pad. $1,912.00; Buy It ...
Jul 28, 2015 | Heating & Cooling
Heat pump runs on electric when outside temperature is higher than cutin
Check your thermostat and heat pump owner's manuals. Thermostat may be programmed to require electric heat at higher temps. Also could be bad outdoor temperature sensor tied to
Heat pump system controls (I had that problem) When was it installed? Warranty thermostat and or Heat pump? Call installer
Thermostat programming is a headache. No help from installer? call customer service heat pump and thermostat. Some possibility of bad installer wiring. There is also a heat pump "defrost" cycle. Usually the Electric coil will turn on to compensate for the Defrost cycle which is just the standard air conditioning mode therefore moves heat from inside to the outside coil to melt the frost. This cycle may be occurring too often. I had that problem. Fixed under warrantee.
Heat pumps are complex machines. The controls even more.
You need a tech, hopfully you are still under warranty.
Hope this helps.
Feb 27, 2015 | Payne 15 SEER R-410A Complete Split System...
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
Hookup thrmastate to conderser
yellow off of the thermostat, & common wire from the transformer in the furnace
Jul 27, 2014 | Rheem R-410A Complete Split System Heat...
Heat pump fan runs backwards
If it's three-phase, swap any two source wires. If it's single-phase, find a fan blade with the opposite twist.
Apr 05, 2014 | Trane Ameristar 5.0 Ton 410A 13 SEER Heat...
3 amp fuse blows after three hours on Goodman 4 ton 16 seer pump
I would suspect you have a problem in the defrost circuit of your heat pump. there are a couple of things you can try. first just run the system on emergency heat and see what happens. you could have a defrost board that is shorting when it kicks into defrost. it sends a signal back to the furnace so it will come on during defrost. if you do not blow a fuse as long as you are running in emergency heat, i would suspect the defrost control board. also you could have a dead short in the wire that runs from the "w" terminal on furnace control board, out to the heat pump. keep in mind that any of the wires could be the cause and i am just tying to give you the most common things. your furnace will still run if you unhook all the low voltage wiring out at the heat pump. if you do this and stop blowing fuses. you know it is something on that wiring. goodl luck.
Jan 26, 2009 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
344 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
