Question about Canon PIXMA MP780 All-In-One InkJet Printer
When fax rings it says it is "receiving" but
  • nicole710 Nov 15, 2010
    HI,
    That didn't work but I did get error code #005. What do I do?
    Thanks,
    Nicole
  • 4,281 Answers
For that you need to reset your printer to factory defaults. Then enable autoanswer in fax settings. For reset follow below./ Press the button repeatedly to display [DEVICE SETTINGS].
Press the left or right arrow to select [RESTORE DEFAULT], then press the button.
Press the left or right arrow to select one of the below options and then press . TELEPHONE NO DATA SETTING DATA ALL DATA
Press the left or right arrow to select [YES] at the confirmation screen, then press . Then go to fax settings and enable Autoanswer. Then save settings. Let me know if you need further assistance.Thanks for using FixYa.
Posted on Nov 11, 2010
HP M1319F Stop Printing Fax Error Reports.
go to the fax repots,conformations,their u select send only.
Dec 02, 2011 | HEWLETT-PACKARD LaserJet M1319F All-In-One...
Will not receive faxes or copy Fax line rings but the machine says its receiving but nothing will print out and it won't copy pages either I've tried turning the machine off for up to 5 minutes,...
To begin troubleshoot,you should set the machine to basic Fax/Tel mode only.
1 If it is not illuminated in green, press (Fax). 2 Press Menu/Set, 2, 1, 2. 3 Press ? or ? to select how long the MFC will ring to alert you that you have a voice call (20, 30, 40 or 70 seconds). Press Menu/Set. 4 Press Stop/Exit. Even if the caller hangs up during the pseudo/double-ringing, the MFC will continue to ring for the set time.
After you confirm your Brother MFC-5440CN is able to receive fax then you can pick one of the 4 modes as describe on the owner manual.
You can download it HERE Detail Information is on 3-10
Jul 28, 2011 | Brother MFC-5440CN All-In-One InkJet...
Hi Everybody, My 6322DN says "printing...", you
First ckeck the line of the telephone,put another printer and see if you recive the fax on other printer.If you not recive fax possible fax board may be faulty.
Mar 16, 2011 | Samsung SCX-6322DN All-In-One Laser...
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Cant receive faxes
Did you try to check the toner?
Try to print if the copy is lighter than before or it cant copy or print then you need to replace your toner cartridge.
Hope it can help you. (" ,)
May 22, 2009 | Samsung CLX 3160fn All-In-One Printer
Cant receive faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
HP640 not receiving with Distinctive Ring Option
You need a dedicated ANALOG phone line.
A DSL filter screens out ANALOG signals to a DSL device.not the other way around. There are no DIGITAL fax machines.
Aug 10, 2008 | HP 640 Inkjet Fax Machine
Receiving Faxes
You will have to ask yourself the question "What has changed?" If you changed nothing, then something else has that is beyond your control. Now, you have to decide whether you are using a single telephone line for faxes and telephone, or whether you have "distinctive ring" also called "smart ring" by some companies. It is not a smart thing to use both. You can print a list of settings to see what the machine is set to do. Now if you want to use distinctive ring, set the ring pattern to the one you have chosen with the tel company. If you have chosen a double ring, and you have set your panasonic telephone to receive on 4 rings, then it will count all the rings and pick up after only 2 sequences. To see if this is the problem just remove the telephone base station from the system and then try to receive a fax.
Jun 08, 2008 | Brother IntelliFAX 2800 Laser Fax
Won't receive fax
Reset RING DELAY so that machine picks up on 1st ring, and does not disconnect before fax can be sent to you.
Jan 07, 2008 | HP 1040 Plain Paper Inkjet Fax
Receiving faxes
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
107 people viewed this question
old marine
old marine
