Question about Panasonic KX-FLB881 All-In-One Laser Printer
Panasonic KX-FLB881 will not power on. No lights, no fan or any other kind of activity observed. Found 2 fuses but both tested good. What can I do to repair this all-in-one?
    President:
  • 3,278 Answers
Hello.
If the printer is connected to a power strip, flip the power strip or connect directly to an A/C outlet to test.
if still a problem, replace the power cable.
If still a problem, sounds like you need a new Power supply: 120 V AC, 60 Hz. . That should be handled by a service person.
Hope this helps.
Posted on Nov 11, 2010
  • NinaE Nov 11, 2010
    Just another thought - be certain you are using a good-quality high speed USB 2.0 cable to connect the All-In-One to your computer's USB 2.0 port.
1991 saturn sl1 is overheating, new thermostat installed, fan is functional, suspecting sensor? and if so, where is it?
Try this for a diagnostic:
Check coolant level. Fill if necessary. Check for leaks.
Start vehicle. Allow to run.
Observe coolant temp gauge. It should slowly climb to center.
Once coolant temp gauge reaches the middle, the coolant fan is triggered to activate by the vehicle's computer (ecm). Fan should come on until temp drops slightly then cycle off.
If fan is working, move to next step. If fan isn't working, possible causes:blown fuse, faulty fan relay, coolant fan switch, faulty cooling fan.
Next step.
If there are no leaks, and the fan works properly as described above, have a compression test performed. This test will basically measure the compression power (in PSI) in each cylinder by screwing a device into the spark plug hole of each cylinder cranking the vehicle (with ignition disabled) and observing the gauge. Each cylinder reading should be significantly close to its next one. If not, suspect a faulty cylinder head gasket.
Aug 28, 2011 | 1991 Saturn SL1
I have a Panasonic KX FLB881 MFC Laser Printer purchased in 2/09. Problems started about 60 days ago. Incoming fax calls ring and ring and the unit will not pick-up. Shortly thereafter network...
The printer has gone into cascade failure, it would require circuit boards to be replaced and with the history I would use it strictly as a printer. The cost of repair would put you over the price you originally paid for the unit, and as you pointed out the mechanics of the item is still fine, I agree with the fact use it until it breaks down.
Jan 07, 2011 | Panasonic KX-FLB881 All-In-One Laser...
How to activate the caller id on Panasonic KX-TG3612BX landline phone....Kindly help
I HAVE A PANASONIC kx-tg3612bx and it is locked by mistake ... please find an answer how to unlocked it
Oct 16, 2010 | Panasonic Cell Phones
I need new panasonic kx-tda 600 pabx software?
KX-TDA100 Maintenance console found at www.wanetelecoms.com
KX-TDA200 Maintenance console found at www.wanetelecoms.com
KX-TDA50G Maintenance console found at www.wanetelecoms.com
Panasonic Unified Maintenance console Version 7.3 found at www.wanetelecoms.com
Mar 04, 2010 | Panasonic (KX-TDA0104) (KXTDA0104) Power...
KXP-4420 will not power up.
I am interested in buying this printer Panasonic LaserPartner KX-P4420 in any condition working or not. Pete (847) 201-1612
Sep 04, 2009 | Panasonic KX-P4420 Laser Printer
Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Mar 10, 2009 | Panasonic KX-TG4500 Phone
Panasonic Microwave oven - cooking operation stops afer 2 seconds
Sounds like a short in the microwave circuit. One or more of the following four components has failed -
Transformer
Magnetron
Diode
Capacitor
Repair is not for the amateur, unless you know how to take things apart, and put them back together EXACTLY as the were found.
Parts are available on the Net, and you can get the P/N's off the old components to identify suppliers of the new ones.
Don't try and measure resistance of the diode. It's impedance is far too high to get a good reading. They're cheap anyway. Always replace the capacitor, they're cheap too. No way to test the magnetron, and the transformer is not easy to test either.
Jan 16, 2009 | Panasonic NN-S952 Microwave Oven
What is the code to record a welcoming message
what system are you using? is it a mailbox or a company greetings?
Jul 01, 2008 | Panasonic KX-T7730 Corded Phone
Doesn't start
1. Test Fuses. Test both under hood power distribution center and the fuse panel under dash. This is done with a test light tool. The test light should illuminate on both sides of the fuse, if not the fuse has failed and needs to be replaced.
2.Testing Fuel Pressure Test for proper fuel pressure with a test gauge on the fuel rail, most throttle body injection cars (TBI) are between 13 psi and 17 psi. and most (DPI) direct port inject systems are between 40 psi and 55 psi. If no or little fuel pressure is observed and there is 12 volt power present the fuel pump, the fuel pump needs replacing.
3.Checking Timing Belt Test for compression by removing a spark plug and insert a compression gauge. Crank the engine over about 5 seconds the gauge should read between 125 psi and 165 psi, if no compression is observed remove front engine cover to inspect timing belt or chain. Crank engine to observe cam rotation, if the cam does not rotate the timing belt or chain has failed. (note: if the timing belt drives the water pump it is best to replace the water pump at this time)
4.Test for Injector Pulse Remove injector connector to insert injector test light (node) or volt meter. Observe light flash or gauge pulse while cranking. If light/voltmeter doesn't respond, an ignition distributor/crank angle sensor (CKS) or an ignition module is most likely your problem.
5.Test for Ignition Spark Remove spark plug wire, insert an extra spark plug into end of wire, rest spark plug next to a ground source then crank engine. You should observe a blue spark between the spark plug gap and ground source. If no spark is observed, an ignition coil, ignition rotor or spark plug wires might have failed. (always keep hands away from engine when cranking)
Jun 16, 2008 | 2000 Nissan Quest
Panasonic KX-FLB881 All-In-One Laser Printer Logo
80 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
