Question about HP Photosmart D7360 All-In-One InkJet Printer
My hp 7360 photsmart printer will not print in red and the cartridges are all at least at half or full
Sounds like the ink jets aree clogged have you tried a print head cleaner cassett
Posted on Nov 11, 2010
  • BugMeNot1 Jan 27, 2011
    I had the same problem with magenta and the ink levels. I solved it opened the printer, removed de battery that was under the upper case at the right side, wait 5 minutes and put it in again. The magenta color print again. And the ink levels detected, returned to ok too.
    This printer is a big ****. i will never buy hp printers again.
Red is printing pink.
A manual and troubleshooting guide for your printer can be found here.
May 05, 2008 | HP Color LaserJet 2600n Printer
HP Photsmart 3210 Printer - Cartridge Access Door is locked in open position. Is there a realease?
Unplug unit first.
Is the print cartridge docked at the far right? If not, move it from side to side to check for paper jams. Most likely there is an obstruction that will not allow it to travel freely. Once cleared, close the cover and reattach the power cord. Power up and see what happens.
Dec 20, 2010 | HP Photosmart 3210 Printer
Photosmart D7360 - message says "ink cartridge empty. To print in color, install the following cartridges: yellow. To print in black ink only, press o.k." I have replaced the cartridge (yellow) and the...
go to hp support>d 7360 >software and drivers. Download (run) latest diagnostic utility 2010-11-09. run test and print test page (only one sentence). worked for me. Took about one minute.
Sep 10, 2010 | HP Photosmart D7360 All-In-One InkJet...
Hp photo smart printer will not print from hp photosmart library software, but will work from toolbar.
This can happen if the printer is not installed from Full photosmart software. or if you changed USB ports where it was pluged into the computer after it was installed.
try deleting the printers and then re install the full photsmart suite.
Dec 10, 2009 | HP Office Equipment & Supplies
The printer tells me to replace an ink cartridge because the ink has been depleted. The cartridge is nearly new, though. Just yesterday it showed to be half full. I have cleaned the printheads and the...
There is a chip on your cartridge that communicates with the printer to estimate how much ink is left in the cartridge. When the chip thinks the cartridge is empty it will refuse to print any more pages no matter how much ink is left in the cartridge. These cartridges are only estimated to print "up to 840 4" x 6" photos, or 80 13" x 19" photos." If it showed half full yesterday and then you put through a large print job it is very likely the cartridge is empty. In any case once the chip thinks it's empty the cartridge needs to be replaced.
Nov 09, 2009 | HP Photosmart Pro B9180 InkJet Printer
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Printer will not start on time
Upon a prompt from the printer, I removed the color cartridge which had run out of ink. Strangely enough, this solved the problem. I can now print anything in black and I will have the color cartridge replaced or refilled.
Leslie lupien
Apr 06, 2008 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart D7360 All-In-One InkJet Printer Logo
198 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
