Question about Amana ARS2661B Side by Side Refrigerator
My Amana ARS2665AC Refrigerator is not cooling properly. I have it set on full level and it takes all day to freeze a glass of water and then not solid.
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
aborcass
  • 2651 Answers
SOURCE: Amana TempAssure
heres a link to your owners manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/12642722.PDF
Posted on Apr 19, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
lenwest
  • 150 Answers
SOURCE: not cooling properly
Sounds like your coils are getting plugged,(excess ice in and around the coils)if you have a cooler or some other place to keep your food cold,turn off or unplug the fridge,you want to defrost it,for the freezer place pans of hot water in it to speed up the process,leave doors open,should only take around 4 to 12 hrs.A good time to clean it to lol.
Hope this helped.Let me know.Also rate me.
For more help go to live chat.
lenwest
Posted on Jan 31, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
Posted on Feb 08, 2009
My amana refrigerator is not cooling, freezer is working
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 22, 2011 | Amana ARB2217CSR Bottom Freezer...
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Bottom is freezing properly but, the top refrigerator is not getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 03, 2010 | Amana ABB1927DE Bottom Freezer...
Refigerator is freezing the food at all settings
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 28, 2010 | Amana ASD2626HE Side by Side Refrigerator
Proper refrigerant levels for Amana Side by Side refrigerator
Hi, normally the suction pressure on a refrigerant -22 system will be between 60 pounds gauge pressure (which keeps it above freezing point) and about 80 pounds. This depends on the temperature condition.Make sure that the superheat and subcooling are correct to see what is to be considered normal for the conditions you have present.
Take care
Jun 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Water leaking out of refrigerator and veggies freezing in fridge
Is it a water/ice dispensing refrigerator? If so, be sure that all water hoses and lines are properly connected and tightened. If not, Check your condensate drain to see if it's clogged. There may be a panel covering it so you may have to take it a part a bit. If it is clogged, unclog it. If it's frozen up then your defrost timer and/or defrost element isn't working properly and should be looked at by someone familiar with electrical wiring.
Mar 13, 2010 | Amana AFD2535DES French Door Refrigerator
Refrigerator and Freezer Not Cooling nor Freezing
That leaves only one possible fault; the volatile component of your coolant/lubricant has escaped.
If the unit has been moved or cleaned carelessly, one of the coolant- bearing tubes has developed a leak. Any refrigeration tech will have a leak detector in his tool set so it shouldn't be difficult to find.
Depending on the area in which you live, expect the troubleshooting and recharging to run ~$150-$250 US.
If you reside in the US, check your local (area) Better Business Bureau for a trustworthy service company.
Mar 16, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana ARS2661B Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
