How do you align the screen on an in-focus dlp
  • 3 more comments
  • Giovanni Latona
    Giovanni Latona Nov 11, 2010
    infocus p61md10 picture dose not sit in the middle of screensits to the left about 3 inches and off the bottom of screen around 1/2 inch
  • Giovanni Latona
    already did all that and picture did not move the reflection is not in center of screen
  • Giovanni Latona
    when i go into the adjustment the lines will move up and down but not side to side and even the up and adjustment up and down make no difference to the screen position
  • Giovanni Latona
    Giovanni Latona Nov 12, 2010
    it happened after i fixed the light engin and put it back in
  • Giovanni Latona
    Giovanni Latona Nov 13, 2010
    trying a new approach thanks
  • 4,472 Answers
First off what do you mean by align the screen? Secondly if you can give me the make and model of the unit I will be glad to assist you further. Please use as much detail as possible as it will make this process go faster and smoother.
Thank you,
Lee
Posted on Nov 11, 2010
  • 2 more comments
  • Lee A.
    Lee A. Nov 11, 2010
    refer to page 60 of the reference guide that you can view at the link below. This is in the picture quality menu then advanced settings menu,you can move the picture vertically and horizontally to best fill the screen. If you need any further assistance please let me know.
    https://portal.infocus.com/support/Produ...
    Thank you and enjoy,
    Lee
  • Lee A.
    Lee A. Nov 11, 2010
    So you changed the horizontal and vertical position to get it centered as best as possible? When you tried moving it to left or right or top to bottom the picture didn't move at all when adjusting these settings? What do you mean by reflection is not in the center of the screen? Using those adjustments you can adjust the picture. Is the picture off center on all inputs the exact same. If it won't adjust then there may be other problems with the tv and it's need of professional repair. Although you should be able to make those manual adjustments to the placement of the image via the menu options that are explained on those pages.
    Thank you,
    Lee
  • Lee A.
    Lee A. Nov 11, 2010
    and the problem is the same with every input? How long have you been having this problem? Did it just appear one day or was it gradual?
    Thanks,
    Lee
  • Lee A.
    Lee A. Nov 12, 2010
    That type of information would be helpful from the beginning. Then there is definitely a deeper issue on the set. Also a few of my other questions haven't been answered. You may need to pull it apart and make sure everything is at it should be.
Can I diagonally adjust (clockwise/counterclockwise) my Mitsubishi DLP TV? The picture is off center
You need to align the optics mechanically. If you changed the dlp chip and its not centered then the chip is not shimmed properly or the reflection mirror behind the lens needs adjustment. You should get a service manual for that chassis and follow the directions. there may be an electronic method but I am not aware of one.
Sep 05, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
I have a Samsung HLP5063 DLP tv. After replacing the bulb and cleaning the inside of the TV, the picture is out of focus on left side and in focus on the right ( varies slowly across the screen). Does...
If you wish to get some details about this, check the site linked here. Adjustment to be done after lamp replacement to DLP TVs are given in detail. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 10, 2013 | Samsung DLP HL-P5663W 56" TV
60 inch Akai DLP TV, PT61DL34 horizontal lines on the screen.
Its a DLP and the optical unit has thousands of tiny micro mirrors that cannot be adjusted.
Apr 29, 2012 | Televison & Video
Whats wrong with my big screen 52 inch
Possible this can be fixed with a professional alignment as the adjustment of the convergence is distorted and so needs a setting.
The Keystone correction and focus must be adjusted.
check this link for tips:
http://htrgroup.com/main.php?section=keystone
Dec 20, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Samsung HL-N4647W 42 inch HDTV DLP TV and the screen is blurry and out of focus with a black curved block across the bottom. what can I do to fix it?
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Samsung HL-R4264W 42" DLP HDTV
My zenith big screen tv is out of focus and we cant find any master focus control. How do we fix the focus?
It is unusual for a rear projection to be out of focus since the projectors are fixed. But, it is common for the projectors to be out of alignment, in which case the picture will look like a bad 3D movie of yesteryear.
Go to the setup options / menu, look for the ALIGN option, follow instructions on screen.
Jun 13, 2010 | Zenith R60V26 60" Rear Projection...
Focusing screen information bar slanting
A scratch on the screen will not effect your photos in anyway, it will just be annoying to you at most. Its possible to hit the prism out of alignment but also very unlikely. If you had to **** it a little bit, its possible you may have moved the actual lcd.
Apr 12, 2010 | Canon EOS Rebel XSi Digital Camera
Two little white bright dots in screen of my samsung dlp tv
these are lit pixels! which can only be caused by a bad dmd chip (the micro-mirror-device). the chip can be replaced but it requires an experienced technitian to align the chip so your picture is straight, centered and in focus.
Jan 04, 2009 | Televison & Video
Philips Projection Screen TV Model PTV915 Horizontal Alignment
Problem solved, needed to get the universal remote i was using set up with the proper code. Once I did that I was able to use the remote to set up the single & multi-zone Red & Blue Alignment.  I also pulled the back plate off and manually adjusted the RGB focus knobs. It seems to be working just fine now.
Thanks to all the other posts.
Nov 25, 2008 | Philips 50P8341 50" Rear Projection...
Lines, colors, delayed images
Had the same problems.  This was after the a power outage.  Had green vertical and horizontal lines, like a checkered shirt.  But I searched online and found the simplest solution.  Just unplug the power.  And it worked.
Jan 02, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
