Question about Timex Ironman Triathlon Traditional 30 Lap Wrist Watch for Women
Used to have a timer and now doesn"t
I used a screwdriver bit which was magnetized. I wanted to change the battery. The new battery doesn;t work now. HOW CAN I DE-GAUSS THE WATCH?
hi u can buy a demagnetizer on E/BAY FOR aprox $15-00.type into search WATCH DEMAGNITIZER...........CHEERS
Sep 12, 2015 | Watches
Worcester MT10 Timer doesn't start. The clock seems to work fine but when it is time to start the heating system doesn't. Please someone csn help me? Thanks
Go to http://www.worcester-bosch.co.uk/homeowner/boilers/boiler-controls/which-controls-go-with-my-boiler/mt10-mechanical-timer. They have a video and instructions plus a downloadable manual to walk you through the process. If it still doesn't work maybe you should return it a get a new one.
Nov 07, 2012 | Watches
Only second hand operates. Rest of the watch won't move.
The seconds hand is purely a 60 second timer mate! It's the small crono dial at the top which is actually the real seconds hand! To get it going you need to unscrew your top adjusting wheel and push it once.....and it will start and the watch will hold time fine!
To stop the large seconds timer hand undo the bottom adjusting wheel and push it! Boom job done!
It caught me out aswell until a watch maker told me Rolex works the same and what you think is your seconds hand is just a timer the other hands won't follow hope this helps chaps
Aug 23, 2012 | Nixon 51-30 Chronograph Wristwatch
I just need online instructions to use the lap timer on my Women's Timex Ironman Triathlon watch. I'm not sure of the model, but I think it's a 50-lap, and it's small. The 4 buttons on the side...
Here is the link that can help you set up your watch. Also here is the All list of timex watch downloadable instruction.
I hope this can help you resolve your issue.
Thank you for choosing Fixya
Mar 06, 2011 | Ironman Timex T5B721 Sports 50 Lap...
Can a cloth "sport type" watch band be used on a
mcdevito75 here, As lomg as the watch band, no matter it"s material fits the watch lugs and your wrist, any band can be used. Your answer is yes.
Feb 09, 2011 | Casio Pathfinder AltimeterBarometer...
How to get the second hand to move
If you are referring to the large orange colored hand, it is NOT the second hand. It is the hand of the depth indicator when the watch is used for diving. Or it is the timer hand when the watch is used as a stop-watch. The second hand is actually on the bottom sub-dial.
Jun 15, 2010 | Citizen Eco-Drive Aqualand BJ2004-08E...
I have a timex w-209 have lost the the timer function
Maybe the battery is weak? Does it have a light? If the battery is failing then the light will be weak or wont work at all. You can check
www.timex.com for your watch, they might have a downloadable manual.
Good Luck!
Jan 09, 2010 | Timex Watches
How can i recall multiple laps during a run?
The Timex Ironman 30 Lap also has a stopwatch that can be used to keep track of split times for racing sports like running or cycling. Press the "Mode" button until the display shows "Chrono," then press and hold the "Set/Recall" button. To start the timer, press the "Start/Split" button. It will continue to run even if you exit to another mode. Pressing the "Stop/Reset" button will stop the chronograph. To record a split time, press the "Start/Split" button again while the timer is running. To see your split times, press the "Set/Recall" button while the watch is in Chrono mode. You can then scroll through the various splits with the plus and minus keys. Press "Set/Recall" again to exit display mode and return to the timer.
Sep 17, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Can't set Seiko Yacht Timer Sports 150
Turn knob to set on "Match" Pull out crown knob. Press both buttons for 3 seconds. When you release both buttons it will beep and both hands start moving. Press either button to stop movement. Then press the top button to set the minute hand to 12 oclock. Press the bottom button to set hours to 12. Press in crown and turn to "Time" Pull out crown and set time the same way.
Mar 01, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Timex Ironman Triathlon Traditional 30 Lap Wrist Watch for Women Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
