Question about Refrigerators
Model ET18PKXGW0 Water collects on drawer above crispers drawers and below the drawers. I wipe it up but it reappears again. What might be causing this?
  • Brigadoon Nov 11, 2010
    Thank you for your help. We will work toward what you've suggested.
  • 4,070 Answers
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Posted on Nov 11, 2010
My crisper drawers collect water
adjust your settings for what you keep in there...and you should be able to solve the problem
Oct 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
Ken more refrigerator has no ice maker but water is pooling under the crisper drawers. Model c21tfa95
Check the drain channel at the rear of the fridge just above the crisper drawers and blow through the drain hole with a drinking straw to clear it.
Jul 02, 2012 | Refrigerators
Frigidaire Gallery, model GLRT183TDW0 Water is leaking underneath, and water is collecting in the bottom under the crisper drawers
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Oct 27, 2010 | Frigidaire Refrigerators
Water dripping from freezer area down in refrigerator water collecting under crisper drawer.
This is most likely due to the defrost drain being restricted, see the link below and let me know if it helps.
Defrost Drain
May 20, 2010 | Refrigerators
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
I have a roper RT21AKXGW00 refrigerator and water settles in the bottom of it and in the crisper draws, is this some sort of blockage?
I have the same model refrigerator and don't have a solution but I think I have more information on the problem. In mine, water will leak periodically from the condenser leading up to the freezer (inside the refrigerator, at the top, center, back of the main compartment). I have seen it leak and it isn't a constant leak but when it leaks it can pour out at a pretty high rate.
In mine, the water will collect in the deli drawer (near the top), the crisper drawers at the bottom, and under the crisper drawers. When it happens, I use a sponge to soak it up and wring into a bowl.
To minimize the impact, I have set up a cup or dish near the back of the fridge to catch the leak. I empty this every couple weeks or whenever it fills up, but I'm looking for more information on a fix (I think the problem has to do with the condenser - that's the lead I got when I found this post).
Aug 01, 2009 | Refrigerators
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
