Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
Coffee jam My machine has coffee, possibly damp, jammed up below the grinder and it won't let coffee out of the ginder and into the place where the water goes through. How can i get to this jam to break it up?
  • 40 Answers
Are you getting any coffee at all? Sounds like your doser door/channel and grinder may be blocked by damp coffee. To remedy this situation, the grinder (and doser door/channel) would have to be cleaned. This is best done by an authorized SAECO Service Center. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
My Saeco Odea Go coffee machine grinder screw rotates with on beans but does not rotate when beans are added. Motor sounds like its working.
There are different possibilities for your problem. First the motor might be damaged and is more weak than before that is why is stop when it need to grind beans. In this case only with replacement motor can solve the problem.
Second probably due to long use of oily coffee or low quality coffee beans or other reason there are coffee grounded in the grinder that become like rubber and does not leave the new coffee to pass through grinding burrs. For this either you have to dismantle the whole grinder and its burrs and clean them with brush or you can use a new magic product that you can fin in eBay it can clean automatically the grinder in 30 second see it at the link
http://www.ebay.com/itm/PULY-GRIND-COFFEE-GRINDER-CLEANER-CRYSTALS-20-GRAMS-PACK-OF-3-PACKETS-/131031511160?ssPageName=STRK:MESE:IT
You can try the above fist and you may solve the problem in minutes if not then you can proceed with the replacement of the ginder burrs or motor.
Jan 10, 2015 | Saeco Odea Go
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Grinder seems jammed....rather than grinding, it hums as if stuck
Dismantle the grinder, you may have a stone in it, a very common cause of jammed grinders.
Mar 29, 2013 | Krups KM7000
Ginder doesn't turn on.
Possibly the Safety Switch is not properly activated. Make sure device lid is in the correct position or the unit will not start.
Please vote if my information is helpful or not. Recommended. Thanks UAW Local 974.
Jun 26, 2011 | DeLonghi DCG2C Electric Blades Grinder
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
Grinder blocked
One posible problem is the coffee shute. This is leading aslo to the passage where you put the grinded coffee and cleaning tablets. This might have be clocked from dry coffee mixed with humitity or steam. So you can use a bending brush similar to the one used to clean babes milk bottles and at the same time vacum with air vacum cleaner.
You can make perfect cleaning if you remove the top platic panel and visual check that everything are perfectly cleaned.
The last thing that is possible for the problem is weak ginder motor which have lost its power so it can grinds but not have the power to push the grinded coffee all the way through chute to the coffee group. In this case you will need new grinder motor.
Hope that this can help you, good luck.
Jun 04, 2010 | Saeco Royal Professional Espresso Machine
Cuisinart burr grind and brew coffee maker
The hopper between the burr grinder and where coffee chutes into the filter is jammed with coffee powder...
First, take out the filter holder and carafe, and place a freash empty filter on the pot base to catch stuff.
Next, take out the beans holder and look for the release lever in the lower left section. Sliding it to the left slides open the door, where you'll probably find loads of powder. You can poke your finger through to get the majority, then use the cleaning brush to get it really clean.
Thanks what fixed mine! (I notice I have to do this about once every few months.)
Sep 09, 2008 | Cuisinart Supreme Grind DBM-8 Electric...
My grinder is jamming
Possible that you installed something incorrectly but I don't think so. It sounds like you're not after the right problem. My guess would be that some bean shards got into the motor or some other place. Most of the motors used on these machines are geared down so that they make more torque and lower speed. Thus...the motor itself is actually quite weak. That's why it is jamming.
What I would start with: take the unit apart as much as you can...by taking out the burr, the receiver cup and all that. Turn the unit over and tap it onto a newspaper covered table with some bit of force. Do it a couple of times. That may fix it. If not, you'll have to disassemble it and find the item jamming it up. Be sure the unit is unplugged when handling it. It is possible that some of the screws are non-tamper. You can get the right bits at the hardware store. Be sure to tighten all screws when you're done.
Nov 20, 2007 | Pasquini Moka Coffee Grinder
Coffee beans will not grind
Your machine will probably need service. The water will cause damage to the grinder burrs.  I can send you instruction on how to clean out the grinder on a Vienna if you provide me will your email address. You can email me at support@cerinicoffee.com.
You are not the first person to do this. These problems come in at least once a week.
Hope this helps.
Johnny
Oct 08, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
335 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
