Question about Cameras
Flas does not go off. I believe that i have it set to go off but it does not and pictures are ver dark & fuzzy. This is a Cyber shot DSC S650.
  • MaryEG Jun 17, 2008
    Flash does not go off, Battery level is high, Flas is set to on
    OK I will take it to be cleaned. Do I have to take it to a Sony store or will any camera store such as Wolfs be able to do it?
    Genius:
  • 3,422 Answers
HI,
If the pictures are dark and fuzzy then its a CCD issue.You will have to get it repaired and thats the only solution.Another thing
I suspect you have somehow gotten the ISO setting set up higher than the lowest one.Make sure it is set to the lowest (80) value. This should give you noise free shots.
Please don't forget to rate or accept the solution.
Goodluck..
Posted on Jun 17, 2008
  • Priya darshan Jun 17, 2008
    Please send it back to sony.Sony used to provide free service for this issue in 2006.So there are a few chances that they might give you s free service or they may charge you a little less.
    If you need anymore help let me know.Please don't forget to accept the solution.
    Genius:
  • 2,028 Answers
Refer to the manual for proper flash settings. If you don't have the manual below is a link for an on line manual. If it still doesn't work properly after you have the correct settings, take it in for a cleaning service and have them check the flash to see if it's gone out.
http://www.nycv.com/manuals/Sony/DSCS650-S700_ENES.pdf
  • Ryan Rogers
    Ryan Rogers Jun 17, 2008
    Good call on the battery. Also there is a 24mb internal memory chip that could be failing.
    Master:
  • 555 Answers
Check your battery level. If the battery is low, the flash cannot operate.
I cant store picture in internal memory .and delete the folder in internal maemory. hw can create under internal memory.
Take out memory card, if any, from Sony DSC-S650 camera memory slot
Go to Menu, Settings and Format memory
This will delete all picture files in internal memory and refresh it for next few pictures.
Internal memory is not big to store many pictures, use memory stick in camera to store many many pictures.
Aug 20, 2010 | Sony Cyber-shot DSC-S650 Digital Camera
My Sony Cyber-Shot DSC-S650 started showing unfocused shots about 7 months ago, and has worsened to almost every shot is unfocused. It does not matter what mode it is in, but I usually use the automatic...
It is problem of lens mechanism and only solution is to replace lens assembly. Local camera repair shop will help you to replace lens assembly because it is not user level repair.
Jun 18, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
I dropped my DSC S650
the ccd imagery sensor is bad.will have to be replaced to work correctly.
May 12, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
My daughter tries to take pictures with her Sony Cyber-shot S650, but all she gets are blurry pictures. What can she do to fix the problem.She has been taking pictures all along with no problem.
She may have shut off the automatic setting for the flash. This will cause blurry shots in darker areas. See if her pix outside in day light are okay. If so, the main wheel on the back of your Sony (I believe it's the top of the wheel) controls the flash. Be sure that is set to on or automatic. Let me know.
Jeff
Mar 27, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Can cyber-shot dsc-s650 b used as a webcam?
yes put a paper clip in the bottom port and plug it in to the wall
Sep 30, 2008 | Sony Cybershot S650 Digital Camera
Sony Cyber Shot Model DSCS650
i have a sony cyber-shot model DSC-S650 camera driver software
Sep 13, 2008 | Sony Cybershot S650 Digital Camera
Camera
reinstall the sony drivers
Aug 25, 2008 | Sony Cybershot S650 Digital Camera
Disassembling of Digital Camera
I can assist you to disassemble DSC-S650
Let me know if you are still interested to apart this camera.
Aug 24, 2008 | Sony Cyber-Shot DSC-P71 Digital Camera
Sony cyber shot s650
I think it is still under warranty because you told its not a year old. Ask Sony about its warranty cover.
http://esupport.sony.com/US
May 30, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Reset factory settings of sony cyber shot DCS-S650
Hello rkhanna,
Initialize function reset all data/ settings to factory defaults including date. I think, LCD Back Light of your cyber-shot is not working and its hardware problem. Contact nearest Sony repair shop.
May 22, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
