Question about Harman Kardon HK595 Computer Speakers
U1, p16ne next to u2, ta8225h are both shorted, replaced both, system still will not power-on, u1 is a power mosfet.
  • 4 Answers
I have a set without power cord or adapter. You can have it..
Posted on Nov 11, 2010
How to find problem on vl470m will not power up
Unless you have an ESR meter and can check all the capacitors in the PSU for ESR, your voltage readings are not valid.
Apr 07, 2017 | Power Up Computers & Internet
Fuse keeps blowing in my philips 32pfl3505d/f7 tv
Good day!!!!
That problem is cause of shorted bridge diode or power mosfet..
just see the picture below to see the image of bridge diode and power mosfet..
If you don't have a tools or you have no electronic background you only have to is order the new power supply board..
I hope this solution will be helpful..Thanks for using fixya....
Sep 04, 2011 | Philips 32PFL3505D 32 in LCD TV
TV LOEWE 8784. Died SPP11N60S5 in the power supply. After replacement of the MOSFET the TV worked for a day then next morning it died again on a start. This way were killed 3 MOSFETs. What could be the...
Possible that when the MOSFET'S were changed the Switch mode oscillations were not proper and so the drivers were driven too much to fail.
It will be best to replace the whole power supply if the mosfets are heating up more than required.
Also replace all the electrolytics and check the SM transformer after the mosfets are replaced and before switch on. Check also the load on the output , if there is any short or leakage on the drive output .
Aug 04, 2011 | Televison & Video
Bonjour, comment faire un reset total pour revenir a la configuration d'origine du d7000? merci
Bonjour cher ami, vous pouvez revenir aux réglages par défaut en appuyant avec un point vert ("Qual-+/-") simultanément pendant quelques secondes.
Pour réinitialiser les paramètres personnalisés que d'autres: se déplacer U1 ou U2 le commutateur de mode U1 ou U2, appuyez sur Menu et vérifier U1 ou U2 Ok sélectionnez Restaurer, cliquez sur OK.
Regards
Mar 13, 2011 | Nikon D7000 Digital Camera
IF I HAVE A MOTOR WITH STAR DELTA WINDING AND NO LABELING IS DONE HOW WILL I CONNECT THE CABLES TO THE MOTOR
the motor will have 3 pairs that can be checked with a ohm meter for continuity. each pair has a start and a finish. usually it would be labelled U1 V1 & W1 for the start and U2 V2 & W2 for the end or finish.
To connect in star ( Motors that start with direct load ) supply cables to U1 ( Red ) V1 ( White ) W1 ( blue ) and bridge out U2 V2 & W2.
To connect in delta Supply cables as above. Bridge U2 to V1 - Bridge V2 to W1 - Bridge W2 to U1.
If you have a reversed winding the motor will growl and not turn.
To reverse direction of rotation swap any 2 supply cables ( But only when the power is OFF )
Mar 09, 2011 | Kitchen Ranges
When the power supply is connected to motherboard it goes off itself
problem lies in the motherboard there is mosfets on the motherboard which is short and because of short circuit protection power supply goes off itself so either replace the motherboard or repair
Feb 01, 2010 | AOpen FSP200-60SAV (5604200H220) 200-Watt...
I need a remote for my split unit which is a MU-09DW-2
I have an MS-09DW-u1 air conditioner and I need a replacement remote too, I just bought a universal remote controller at Meritline.com for $8.99. I'll let you know how it works when I get it and try it out.
Mar 26, 2009 | Heating & Cooling
ED14 on the powersupply of lrm-519 need replacing
This item is a MOSFET Power Switch. The part # FSDH0165D. Can be found below
www.mouser.com/Search/Refine.aspx?Keyword=512-FSDH0165D
Jan 18, 2009 | LG Electronics LRM-519 Digital Media...
Harman Kardon HK595 Computer Speakers Logo
69 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
