Question about HP OfficeJet 6210 All-In-One InkJet Printer
My printer display saids to "remove and check right cartridge" i've done that several times, no respond. help!
I had same problem with different printer usually new print cassets can be slow starters. I tried make sure the strip is full off the new cassette also the ink apperture is open use a nail.
Run machine head clearing routine. If all this fails change cassett Good luck!
Posted on Nov 11, 2010
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
"The yellow 'Alarm' light will not go off after changing cartridges.
Try removing and reinserting the cart. Or try a new cart. It sounds like it's not recognizing that a new cart has been inserted. It could be a faulty/sticky switch where the cart is detected.
Jun 21, 2012 | Canon Office Equipment & Supplies
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
My Printer HP PSC 1315 is displaying "Printer Cartridge Error" with "Check Printer Cartridge" light Blinking. Am not able to Neither Printer nor Scan. I tried finding any solutions...
Did you try solutions from this site? Scroll down to Issue: The Check Print Cartridge light blinks, and click on Solutions.
If I helped you, please take time to rate my answer :)
Sep 06, 2011 | HP PSC 1315 All-In-One InkJet Printer
My hp2400 series printer is stuck on the message "Remove and check the right cartridge". I have done this several times and it still doesn't work/ Please help.
If this is a new cartridge make sure the shipping tape has been removed from the print head before inserting into the printer.
Oct 31, 2010 | Computers & Internet
Replaced a printer cartridge type 106 with same. Everything was done according instruction. The printer printed several pages and now will not print anything but a blank page. what needs to be done to...
Check to see that the toner cartridge does not still have a "Pull Strip" on the cartridge. or Remove the cartridge and gently rock the cartridge a few times in your hands and re-install.
Jun 25, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP OfficeJet 6210 All-In-One InkJet Printer Logo
    52 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
