Question about Empire RH35 Mid-Size Heater
I have an empire rh 35 space heater it is very hard to lite the pilot lite may be an igniter problem? should i replace the igniter system
4 Suggested Answers
jeffk14
  • 16 Answers
SOURCE: I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Posted on Nov 20, 2008
  • 69 Answers
SOURCE: wall heater burners wont ignite
you may have a bad gas valve
Posted on Dec 19, 2008
SOURCE: HOW TO LIGHT PILOT ON EMPIRE CORCHO WALL HEATER
I have tried to light my empire wall furnace by pressing the button and I have the gas on and it won't light
Posted on Oct 09, 2010
I have an empire dv-60-18pp that the pilot won't stay lit...why?
Thermocouple problem. make sure it is in the flame. make sure it is not covered with patina. if it still wont work replace thermocouple.
Jan 30, 2015 | Empire Heating & Cooling
Pilot won't light on rh-65 vented room heater
The pilot is dirty. You need to take the pilot assembly apart and clean the orfice and hood. Make sure to spray for leaks after the gas valve is in the open position.
Mar 04, 2014 | Empire Comfort Systems RH-65BLP 65,000 BTU...
So much air blowing in the pilot on DV-35-2SG heater won't stay lit
Unfortunately if its wall vented the wind can hit it just right and pop off the pilot this happens on older models a lot check your vent if its too much of an aggravation you may have to relocate it
Jan 17, 2013 | Empire DV-35 Heater
Empire heater is lite but wont come on
have you check the switch if it is break ?or maybe it has used for a long time .it was out of work .and couldn't discover .you should change a new one.
wall light
May 03, 2012 | Empire DV-35 Heater
Poilt is very week and will not open gas valve
The reason the control valve is opening slowly is the the Thermopile needs to be replaced. The Thermopile generates millivolts of electricity from the heat of the pilot flame, which then opens the gas valve when heat is called for. Also, check the pilot flame to make sure it's engulfing the thermopile. If it's not the pilot needs to be cleaned.
The Empire Comfort Systems, Thermopile part number is 672063
If I can be of further help, please let me know through the leave a comment link.
Apr 19, 2011 | Empire DV-35 Heater
PILOT FOR EMPIRE WALL HEATER WONT STAY LIT. I HAVE ALREADY REPLACED THE THERMOCOUPLE
are you sure the problem is with the thermocouple? is the pilot sharp and blue? it is unconnon for the magnet in a gas valve to go bad but it does happen. place the thermocouple in the valve and with it in front of you heat it with a match or lighter for 30 sec. now try and light the pilot quickly. if it lights the the problem would be the pilot, if not then the valve. is this a milivolt system or hydrolic t stat.
Jan 29, 2011 | Empire DVC-35 Wall Mounted Panel Heater
Heater doesn't start.
Check the length of your thermostat wire. Mine was about 10ft and I experienced the same problem. Reduced it to 6 and the problem was fixed.
Oct 12, 2009 | Empire DV-35 Heater
I have a propane laars lite 2. The pilot is on but the gas valve will not open
is the tank a least 35 % full check for all the valves if not two solution replace ignition control or gas valve very hard to guess over this
Sep 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Empire RH35 Mid-Size Heater Logo
89 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
