Question about Roper REX3614KW Electric Dryer
The dryer will not heat. Less than a year old and previously worked. I am not sure if I have the three wire hookup correct? Does the wire from the green grounding lug go under the center ground wire?
  • Roper Master
  • 8,220 Answers
Posted on Nov 11, 2010
Hello: I have a Maytag MDE9700AYM that was purchased three years ago but has been installed for less than one year. After the unit runs for 10-20 minutes, the circuit breakers trips off. Otherwise the...
It's possibly the circuit breaker rather than the dryer itself. Usually when it trips, it is overloaded or shorted. Overload can be a result of a loose connection or a bad heating element,when you remove the old breaker, see if it has some noticeable burn/corrosion marks where the wire is screwed down, I think replacing the breaker will fix the problem. Hope this helped Tim
Nov 07, 2010 | Maytag MDE9700AYM Electric Dryer
Just got the unit from a friend and had to change the plugs from four to three and it turns on but there is no heat. the dryer is less than a year old and worked three days ago.
the only difference is the 4 prong has a ground wire,if you put the white in the middle,the red where it was before on one side and the black on the other side it should work.check the back of the dryer to make sure you have the correct voltage,with a meter set on volts,touch the white and red wire and you should have 110,then touch the white and black and you should have 110.if not you have a problem with a fuse in the house.one fuse runs the dryer and another is for heat but if you have 220 or 240 in the back of dryer something is blown in the dryer.you'll need to check out the thermostats and the heater in the dryer.let me know what you find.your vent line could be clogged with lint and popped the high limit thermostat on the heater box
May 15, 2010 | Kenmore 63942 Dryer
Lg dlg 7188rm gas dryer will not heat
Check to make sure that the thermal fuse is not blown. Small plastic piece with 2 wires coming off of it. Typically this is problem.
Feb 01, 2010 | LG DLG7188 Gas Dryer
Dryer Stopped Heating
Use a multimeter to check the heating element. You can't always go by looks. Check continuity and if there is none, the element is defective. Another thing to check is the thermal fuse. It is about an inch long and is usually attached to the exhaust duct. Use the meter to check it as well and if defective, replace it. Sure hope this helped and best wishes.
Jul 28, 2009 | Whirlpool LER5636P Electric Dryer
I need to know how to wire the plug into the back of the dryer
Current electrical codes require a 4 wire hookup for all dryers. There needs to be a separate ground and neutral. If you do not know how to hookup the 4 wire version, it is worth calling an electrician to install the correct wires. If there is a problem down the line, the improper installation will invalidate your insurance claim. Dan
Jun 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The electric dryer is about 10 years old. Came with house. It does not dry a load such as towels in less than 1.5 hrs. Typical with our previous GE was 30-40 minutes. Would a heating element be gone, dirt...
if it still gets hot its not the element your dryer vent could be stopped up not allowing air flow if its not getting hot the element is easy to change pull the back off after unplugging the dryer the wires easily unplug and take off screws you can get the part number from your local dealer with the model and serial numbers
Apr 07, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
No Heat
no the four wire cord just has an extra green ground wire,the three pong will work just make sure you have the middle wire on the cord on the middle of the terminal block,let me know how you make out-mike
Apr 02, 2009 | Whirlpool LER4634J Electric Dryer
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
DRYER TUMBLES BUT WILL NOT HEAT
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
Jan 18, 2009 | GE DBXR463GD Gas Dryer
Roper REX3614KW Electric Dryer Logo
32 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
