Question about Maytag Dryers
I have a Maytag dryer, model number DE512. The dryer works fine but as noisy on startup and then makes a rumbling noise as it continues through the dry cycle. I always clean the lint screen after each use, but the dryer is 21 years old and has never required any other maintenance. Can you please advise as to what the problem could be? Rollers, belt, other types of cleaning?? Hope you can help.
jsrock516
  • 5911 Answers
SOURCE: dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Posted on Jul 28, 2007
appldoctom
  • 311 Answers
SOURCE: I have a noisy Maytag LDG 7500 gas dryer.
thats your blower wheel.pop the hood take off the frount the blower is at the bottem.if you are able to turn it and the drum dose not turn thats your problem
Posted on Dec 31, 2008
SOURCE: Maytag Dryer clunking noise
may 26 2009
My maytag dryer is making a very loud squelling sounds in some of it cycles. still drying ok
gmalcom
Posted on May 26, 2009
pumpkinman
  • 1165 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
hunter19_46m
  • 7482 Answers
SOURCE: maytag dryer model # de512,
Hi iprenorris...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 21, 2011
How to replace belt in Maytag dryer DE512
Hello
Watch this youtube video it will show you step by step how to replace the belt
http://youtu.be/6ufArteqWXk
Jul 23, 2011 | Dryers
Maytag model lde7500ace. It is making a rumbling noise with vibration this has been slowly getting worse over a few weeks, otherwise works fine
drum roller/glides, idler assembly:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 11, 2010 | Dryers
Dryer makes loud continuous rumbling noise
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Nov 28, 2010 | Kenmore Dryers
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Mar 21, 2009 | Maytag MDE2600 Electric Dryer
Frigidaire dryer making rumbling noise .
I work for an Appliance Wholesale Company at www.appliancepartsonline.net
Is the dishwasher a front loader or a top loader? That will matter!
Give me the model number of the unit and I will tell you how to stop the "rumbling"
thnx
info@appliancepartsonline.net
Feb 16, 2009 | Frigidaire Dryers
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Dec 31, 2008 | Maytag PYE2300AY Electric Dryer
Rumbling noise
Time to call GHOST BUSTERS!
Here is a good service!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 22, 2008 | Maytag Performa PAV2200
Dryers Logo
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Charles T Nevin
Charles T Nevin
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
