Question about Dishwashers
My dishwasher won't drain completely in the last cycle so in other words water remains in the bottom of the washer. Don't know how to take it apart and clean out.
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Nov 12, 2010
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
Hope this helps
Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
After dishwasher run through it's cycle, the water does not drain properly and remains in bottom of the dishwasher
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 10, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
After wash cycles are completed there is about 1/2 gallon of water remaining in the bottom of the washer. I checked the drain that exits into a disposal and that is clear. All around the bottom of the...
Hi and welcome to FixYa. I am Kelly. Most dishwashers are connected to the sink / garbage disposal via an Air Gap. The Air Gap gets debris inside it that blocks the drain passages. Check out this video on how to clean it:
Jul 01, 2010 | Maytag 24 in. MDBH950AW Built-in...
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
Dishwasher not rince & when cycle ends not clear water remains
check the drain connection where it connect to the sink these are bad to clog. In your case it may be a partial clog also check for any kinks in the drain line.make sure your line go above the connection point and then back down .This will stop water from flowing from the sink.
You can take apart the pump usually torx screws and remove any debris. Do this last
Dec 12, 2008 | Frigidaire FDB658RA Built-in Dishwasher
Drainage problem
cycle switch on the front is most likely bad
Jan 09, 2008 | Hotpoint 24 in. HDA3740G Built-in...
Dishwashers Logo
129 people viewed this question
Top Dishwashers Experts
