It says clear paper jam - Office Equipment & Supplies
  • 231 Answers
What brand of fax machine do you use?
try to open the fax machine ande see if there is any paper jamed or piece of paper jamed at the sensor.
Posted on Nov 11, 2010
Remove paper jam
you MUST get the tiny paper out of the machine. It will make more jams for sure. If you do not have a manual or someone handy try looking up your printer model on the web for jam clearing advice at the location where the paper ripped. Usually there are numbers. Sorry!
Feb 20, 2015 | Office Equipment & Supplies
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jam
Dear sir,
i am giving u setp to solved your problem,
Step one: Remove any loose paper.
Step two: Clear the jam from the back of the All-in-One
Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Clear paper jam
may be there is small pice of paper inside just remove that.
Jan 20, 2010 | Canon FAX JX200 - Fax / copier - ink-jet...
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam
Solution one: Clear the jam from the back of the All-in-One Follow these steps to clear a paper jam from the back of the product. Step one: Remove any loose paper Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back CAUTION: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the product slowly and gently. Avoid touching the internal components of the product.
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear door. Push in the two release tabs, and then pull the door toward you.
Feb 01, 2009 | Lexmark P6250 All-In-One InkJet Photo...
51 people viewed this question
jasbo
jasbo
