Question about Husqvarna Designer I
I use a D! . The bobin winder is very tempermentl. Most of the time it refuses to work, making it very difficult to fill the bobbin. I have had it fixed twice, the last time a year ago. Also when using the automatic scissor the bobbin thread doed not come up automatically, causing me to rethread the bobbin each time. And the automaric needle hreader does not work , this also was "fixed" a year ago. Thanks for your comments. Pauline
  • 201 Answers
Sorry to hear you are having so many irritating problems with your lovely machine, Pauline. This is going to get long, so please bear with me. It sounds like your bobbins are wound too tight and that is why the bobbin thread is popping back down into its hole and not being taken up by the thread when you sew. This happens to me only when I am embroidering and my solution is to keep a pair of tweezers handy. If I can see a tiny bit of the bobbin through the feed dog hole, grab it and pull out about 1/2", this should be enough to make the machine pick it up. Otherwise, remove the bobbin case cover and pull out some thread. Take it to the bobbin thread cutter but don't use the cutter. Just leave about 1/4" hanging outside before replacing the bobbin cover.
Here is my method for winding bobbins.Important: reduce machine speed by at least two clicks. Put bobbin on spindle and carefully push it down into position. Flip the spool pin out so it is at a right angle to the machine, make sure the larger spool holder is on the bottom. Place the thread on this pin so that the thread spools off from the right-hand side. Take thread end down the right-hand side and then under the silver thread guide that is just below the tension disks, then around and over the top and over to the next bobbin winding thread guide (this makes a sort of half figure-of-eight around the silver guide). Thread goes under the next guide (sort of hook under the thread spindle), over the next silver guide and over the top of the bobbin. Wind it firmly around the bobbin about four times, cut the end with the cutter beside the bobbin winder and let the end hang. Press On button. The wound bobbin should have a slight springy touch - should not be hard, nor loose and spongey. Hard means it is too tight. If it is hard and tight, omit the figure-of-eight winding as instructed above and just wind it around the first silver guide in the usual manner i.e. around the left-hand side, under the guide and over to the next guide. You could purchase a side-winder bobbin winding machine for a fairly small outlay if you think that would suit you better. I own one but rarely use it, finding them fiddly and with a not very satisfactory bobbin at the end, plus it's another gadget to have on the table and requiring a power point. I can live without it LOL!
Needle threaders seem to be either in the "Works" or "Doesn't Work" category. I have no trouble at all with mine, but I know lots of other Des.1 owners who do. It may need re-setting again - sorry! - but once it is fixed, here is how it should work and how to keep it "in trim". If you, like me, do not have excellent eyesight, get hold of a magnifying glass. You won't need it for every time you use the threader but you need to see clearly just what is happening. Push the needle up/down button once (needle descends), then again (needle comes up). It is now in the perfect position for threading. Lower the threader lever - a very fine wire hook should go through the needle's eye. You need to do this slowly and carefully. If the wire crashes against the back of the needle, it bends and will no longer go where it should. You can straighten the wire to some extent if needed. Needles smaller than 75 are difficult to thread - the wire barely fits through the eye unless it is a special metallic or similar needle with an enlarged eye. Once the hook is through the eye, bring the thread down and around the left-hand side of the flat hook on the left of the threader, under the hook and across to the needle. I like to gently lean the thread against the tip of the needle (hard when you can't see it, so wear your glasses or use the magnifying glass, but becomes easier with practice) then slide it up until it is under the wire poking through the needle's eye. At this point, gently release the needle threader. Don't let go suddenly and have it whizz back up inside the machine. You are trying to gently draw the thread back through the eye. There will be a little loop at the back of the needle which you grab and tug until the thread end is through.
Good luck, Pauline and I hope that some of the foregoing will be helpful to you.
Posted on Nov 16, 2010
When I try to fill my bobbin the thread gets all balled up on top of the bobbin instead of filling it. What should I do?
Consult your owner's manual. Chances are you may be threading the thread incorrectly. Make sure it is going through the bobbin winder tension guide before going to the bobbin winder mechanism.
If it continues, the bobbin winder may need a height adjustment. I had that issue with a machine that the case surrounding the bobbin mechanism was slightly misaligned. Once it was fixed, the bobbin winder worked perfectly.
Dec 01, 2015 | Sewing Machines
Why won't the bobbin winder work
Difficult to diagnose without knowing the make/model and the symptoms. Best advice is to consult the owner's manual.
Make sure the handwheel center cap is loosened before winding the bobbin. Also, snap the lever toward the bobbin to activate the bobbin winder. Confirm that the correct sequence is followed in threading from the spool to the bobbin winder.
If you are unable to get the bobbin winder to work, for ~$25 you can pick up a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or even online (Amazon.com).
Nov 10, 2015 | Sewing Machines
I would like to take the front or top off the sewing machine to see if the bobin winder is stuck.
There are several set in screws on back side of unit, remove all visible ones. making sure there are know covered by tape (refurbished do) then the o-ring gasket on bobbin winder is probably deterriated, replace and it should be spinning.
Oct 08, 2014 | Brother ES2000 Computerized Sewing Machine
My kenmore model#158.19411 bobin not filling
Take off the lid by removing the 2 screws, check if the bobbin winder tire is worn out (buy a new one at any service shop,) and make sure the bobbin winder shaft is spinning easily (oil). Don't get oil on the tire or it won't have traction.
Oct 03, 2014 | Sewing Machines
Sewing machine problem
if the bobbin winder spindle will not return to it's original position, then there's a part in the machine that not working correctly, & it needs to be serviced,
Feb 27, 2012 | Husqvarna Sewing Machines
Bobin winder won't wind
Check your manual to be sure your are setting up as you should.
If the winder still does not work, you can take it to a dealer for repair and pay out around $80, or purchase the SideWinder bobbin winder for less than $30. I have seen them for less than $20 at Hancock Fabric.
I have one that I use from time to time and it does a very good job. I really did not need it....just can't pass up a new notion.
Feb 23, 2010 | Brother SE-270D Computerized Sewing...
Toyota sewing machinge 5500
If I understand the problem, the bobin winder has probably lost a rubber 'o' ring.
Unscrew the two top screws and remove the top cover. At the base of the bobin spindle is a metal disk that should have a rubber 'o' ring on it. This will perish over time and break off.
When the bobin winder is pushed sideways into the active position, this should contact the main turning handle thingy (that's a technical term) and be spun around. Check if the bobin 'o' ring is making contact or if it is even there at all. Any sewing machine repair shop (or good automotive store if you're desperate) will have a replacement.
Oct 09, 2008 | Sewing Machines
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
148 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
