I am trying to replace the drive belt on my Kenmore front load washer, model 41747102700. The old belt just fell off and was laying on the floor of the washer. In attempting to replace it it seems as if I would have to stretch it 3 to 4 inches to reach the motor. Any help would be appreciated.
  • 246 Answers
The belts on front load washers are very tight. The trick to putting them on is starting the motor side first. Wrap your belt around the motor shaft then while keeping your fingers there to hold it in place, use your other hand to start pushing the belt on the larger pulley while you turn it. The belt is going to try and work back off the motor pulley while you are turning the large pulley which is why you have to keep your fingers down there to hold it on. The new belt will have several grooves on it. Make sure these grooves are all meshed in the motor pulley grooves.
Posted on Jun 17, 2008
Transporting a Kenmore front load washer and gas dryer
Yes you can lay them down. Some modals call for 24 hour reaping time before you can plugin to run. Reaping meaning some modal have the new R134A coolant in them so if they lay down wait 24 hours before use. Gas you can just lay then down and brace it so it can't move around.
Aug 02, 2016 | Kenmore Washing Machines
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
Looks like a belt underneath fell off.whats that for and how do you replace it
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
If it's a direct drive washer, the belt is likely simply a sound deadening device (a rubber belt about 1/4" high and about 8" around ) that fits around the brake drum.
If that is it, and everything else is fine, you don't have a problem.
Mar 12, 2010 | Kenmore 22422 Top Load Washer
How do I replace the belt on my Kenmore top loading washing machine?
  1. Turn off the washer and unplug it.
  2. Lay the washer on its side so that you can get underneath it.
  3. Remove the old belt by rotating the pulleys that hold it while pulling the belt off of them.
  4. Find the markings on the belt that indicate its model number.
  5. Use this model number to order a new belt from an appliance store.
  6. Attach the new belt by placing it over the pulleys while slowly rotating them.
  7. Return the washer to the upright position and plug it back in.
Jan 25, 2010 | Kenmore Washing Machines
There is a rubber burning smell during the spin cycle on my stacking washer/dryer applicance. It is about 10 years old. How do I open the applicance and check the belts during the spin cycle?
This is a drive blet problem
To replace the drive belt, you will need to open the access panel or in some cases tip the washer onto its side to expose the belt on the bottom. Start by removing the back cover, and look for a belt. If you do not see a belt (or a place for a belt - the belt itself may have broken and is hidden from view) and you can see the floor then your washer is a direct drive model that does not use a belt. If you cannot see the floor because there is a steel floor in the washer, locate the motor and determine if it extends through the bottom plate. If so, then the belt is accessed from beneath the washer.
If you have to tip the washer over, place a large piece of cardboard on the floor to protect the floor and the washer's finish. Because a washer is pretty heavy, you will need an able-bodied assistant to safely tip the washer onto its side. Also, there will be some water remaining in the washer, so have sponges and towels ready to clean up any spill.
To remove the old belt unscrew the clamps securing the pump coupling ( a leathery or rubber flexible part that connects the motor to the water pump). Remove the pump coupling to slip the old belt out. Some models instead require you to loosen the motor mounting bolts and shift it inward to relieve tension on the belt. Remove the old belt.
Place the new belt over the transmission pulley first then place it over the motor pulley. If it is too tight, place the belt over the motor pulley's nearest edge and then slowly turn the motor pulley to pull the belt around and into the pulley. Replace the pump coupling or tighten the motor mounting bolts. The belt should deflect no more than one half inch when you press on the longest straight run.
Replace the cover and test the washer for proper operation
Sep 29, 2009 | Kenmore Washing Machines
How difficult to replace belt for front load clothes washer Kenmore 8 years old? I'm an average handyman.
the belt is held by pulleys, there is an ajustment bolt loosen this (should be marked) to loosen the belt. some models have a frame bolt that must be removed to get the belt off. this repair should be fairly easy to do.
Apr 21, 2009 | Kenmore 22422 Top Load Washer
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite he3 model # 11044832200 gives me a f15 error code. have already unplugged and replugged every connection between the CCU, MCU and drive motor, machine will fill and drain properly but will...
it because you change cycles in the wash mode,,over reset...all fixes accept reset unplug .needs technician...if you fell you can do this repost question,,as replacing motor control unit
Dec 26, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
