Question about Whirlpool Refrigerators
When the refrig compressor tries to kick on it immediately kicks off..is this a relay switch?
  • Whirlpool Master
  • 1,344 Answers
With whirlpool, yes. You probably hear a hum then a click afterards. This is a really common problem with this brand. Unplug the machine and take the relay which is located on the side of the compressor off. once you have done that shake it. If you hear any rattling or see any kind of black stuff come out of it replace the relay. This is a really easy job. If you have never had it changed before then I'm 99% sure thats the only problem you'll have.
Posted on Nov 11, 2010
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
Have a whirlpool top side by side refrigator with bottom freezer drawer. The freezer compressor kicks on but shuts right off
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 24, 2011 | Refrigerators
My parents gave me their older refrigator as a spare,,,,it wasnt plugged uo for like 3 moths after i got it to my house but yeaterday i rolled it out,,,cleaned the coils and plugged it back up.it ran for...
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it.
If it runs then that cold control is the problem.
If this doesn't work Do this
That is probably the compressor relay or cold control (Thermostat
The relay is on the compressor and needs replaced
Thats what is happening with yours
also try hooking the two wires together on the cold control to route around the cold control.
Leo Ponder
Aug 16, 2011 | Refrigerators
French 3 door LG refrig.. Not cooling but compressor acts like it wants to kick on. The other guy said it was something wrong with my defrost cycle/ The refrig is defrosted but when plugged back in it is...
You either have a defective start relay or a defective compressor.
If it is clicking every 45 seconds or so,you can try a new start relay.
Feel the compressor.
Is it hot to the touch?
Is the compressor fan motor running?
Apr 06, 2011 | LG Refrigerators
I have a saniserv 707a and the product won't freeze. The refrig line is freezing right after compressor switch.
my saniserve ice cream machine will not get freeze hard or freeze when u press the button on for the compressor to kick , it will not kick in.
May 12, 2010 | SaniServ 401 20 Quart Ice Cream Maker
My a/c is not blowing cold air. The compressor does not kick on when I turn the a/c on. I have tried adding freon to it but it does not allow any freon to enter the system. I have checked all the fuses and...
The compressor probably isn't kicking on beacuse it is low on freon. It won't take freon when you try because the compressor needs to be running to draw it in. Sounds like a catch 22 doesn't it? There is a low pressure switch either in the filter/drier, or on the low pressure line. If you unplug the switch and hook a jumper between the two pins, the compressor should kick on, allowing you to add freon. Hope this helps...
Jul 14, 2009 | 2006 Kia Sorento
Air conditioner doesn't run.
it is the low pressure switch trying to save the compressor. the system is low on refrigant. on this ford it should be R-134a all new cars are that refrigant.
Jul 08, 2009 | 1998 Ford Explorer
Need schematic for refrig repair
i need to know how much pressure gauge on low and high for two side whirlpool refrige
Nov 26, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
NISSAN 240SX A/C PROBLEM.
HI,
Yeah have the voltage to the compressor checked!..By turning on the A/C when hot (and not working),Add a test wire to the 12v output of the A/C relay, to "boost" the 12v amps/voltage going to the compressor clutch. As soon as the test wire touches a strong 12v source, the clutch immediately kicks in. Remember that 12v already existed on that wire, but a stronger 12v source helped give the clutch the extra kick it needs. Thank you!!..Hope this helps you out buddy!!.. :)
Jul 19, 2008 | 1993 Nissan 240SX
Freezer not freezing, everything is thawing.. only 3 yrs old, refrig part only 47 degrees
sounds like your compressor is not starting up. unplug your refrig then remove the start relay from the side of the compressor. shake the relay if you hear alot of rattling around in the relay then most likely that is all thats wrong. if it doesnt rattle alot then possibly the compressor is locked up and is bad.
when you shake the relay if its broken internally usually little peices of ceramic will fall out of it. so shake it over a peice of paper to see if that happens/..
Dec 16, 2007 | Jenn-Air JCD2290HES Side by Side...
Refrigerators Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
