Question about Water Heater Innovations MR85245 High Efficiency Electric Heater
I want some topic for water problem by population
    Genius:
  • 1,015 Answers
Some of my favorites are easy ways to conserve water,prevention of backflow and cross connections and public dangers they can present. Also filtration,ozone treatment,reverse osmosis systems,options to water softening without using salt and grond water pollution by private, agricultural,and industry. You can get a wealth of information from EPA, local building dept. local and state health agencies. Hope this helps. Thanks
Posted on Nov 11, 2010
What are the benefits from assignment expert?
these are the benefit- Better understanding of the topic, Expert guidance, Effective end result, No fear of deadline failure.
Avail assignment help service from expert.
Assignment Help UK Best Online University Assignment Writing Help
Apr 13, 2017 | Water Heaters
No hot water , no heater
No Hot Water - Electric Water Heater Troubleshooting
www.whirlpoolwaterheaters.com/owner-center/.../no-hot-water/
Whirlpool's video explaining potential reasons your water heater is not working ... Troubleshooting and Repair · No Hot Water (Video) · Replacing a Heating ...
Electric Water Heater Repair and Troubleshooting ' Whirlpool
www.whirlpoolwaterheaters.com/owner.../troubleshooting-repair/
Troubleshooting and Repair of a Standard Electric Water Heater. No Hot Water ... Not getting power is a common reason new water heaters don't work.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
My tenant has a electric 30 gallon water tank. cimarron by Reheem. model ... So if u notice your water is overly hot and then notice no hot water ...
Dec 26, 2015 | Water Water Heaters
We've got a Bosch Gas Heater which works fine 1
please check response to later post on this topic.
Sep 21, 2014 | Water Heaters
Just bought gcv 50 300 series. see lots of problems with gcv 50 100 pilot light not staying lit. my new water heater has different control on it. Did they fix their problems with this new controller?
You offer much opportunity for research and discussion.
This would be a good topic for the Tank forum as there are professional plumbers with specific and general expertise on different model numbers.
http://www.waterheaterrescue.com/TheTank.html
Fixya is not a forum since we parcel an answer, then move to next question.
Discussion is not common, and typically one person answers this question, and then that question is removed off the question board.
If you are wishing to diagnose pilot light yourself, assuming product is not defective, and you are not already professional in the field, then following links offer resource:
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Gas-venting-specs.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
Why shoul health care provier hire you
Because you posted mis-spelled, mis-punctuated insurance question under water heaters and therefore can read, write and differentiate complicated tasks.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater, resume, language software or any do-it-yourself project.
Fixya is always less expensive than a service call, or advanced degree.
Mar 08, 2011 | Water Heaters
Low boy water heater leaks at point where cold water pipe enters caseing.The leak is below the threads.The caseing is rusted at the point where the pipe goes through.Can this rusted place be patched or...
1) Your water heater needs to be replaced.
It cannot be repaired.
Tanks rust out after anode rod is depleted unless anode is inspected and replaced 1-3 years.
Water softener causes anode to deplete quicker, so inspect every 2 years.
Also stray household current can cause tank to rust out. Put bare copper ground wire between hot and cold pipes on new heater.
2) First thing is protect yourself from tank rupture where water heater bursts open and water runs until it's shut off. Ruptured tanks are big topic in homeowner insurance industry today because they cause major damage inside house.
- Turn off heat source so tank is not under pressure:
Gas: Rotate dial to pilot so pilot light stays lit, but burner does not turn on
Electric: turn off circuit breaker
- Turn off water going into tank using shut off above tank.
- Open hot side to bathtub to relieve pressure from tank.
- Check label on side of tank to get tank specifications for replacement.
3) What to do until replacement.
You can get by for a while on leaking tank by turning it ON only when needed.
Make sure tank is full of water before turning heat source back on.
This will buy time until replacement.
Electric tank heats 21 gallons water per hour.
Gas water heater 41 gallons per hour
Shower uses 6-9 gallons hot water, bath uses 12-15 gallon hot water.
4) Additional reading so next tank lasts longer
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Dec 05, 2010 | Water Heaters
Electric water heater out. Already replaced elements and breaker. Getting power to the unit but no hot water. What now?
Have you reset thermostat on the heater, it will be the top thermostat right above the element. It will have a red reset button to press to reset. They will trip causing the heater not to work till it's reset or replaced due to thermostat gone bad. Chances are you may only have to reset it.
Please go to link below with to get some very helpful information on these topic's. If you replaced everything but the thermostat or reset it that's all left to hold out power to water heater. The thermostat is a safety device to protect the home owner. You may have had a element short out to trip it.
It will take 30 to 45 minutes to start to produce hot water after power comes back on.
http://www.water-heater-repair-guide.com/electricwaterheatertroubleshooting.html
Jun 17, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Pilot light goes out after water is heated i think when main flame cuts out,''blowback''? unitrol valve
Sounds like a draft is putting flame out or a faulty thermocouple. Check this web site out on This Old House about this topic.
http://www.thisoldhouse.com/toh/asktoh/question/0,,20054282,00.html
Jun 16, 2010 | Water Heaters
Runs out of hot water
I wonder if you have this problem below caused by a drop in water pressure from someone flushing a toilet or a washing machine. I would call the company to remedy this issue.
17. What is a cold water sandwich effect? The term “cold water sandwich effect” is a term that is used to describe the introduction of cold water into the hot water supply line during frequent on/off operation of an instantaneous water heater. The cold water sandwich effect, when present, appears as a momentary drop in hot water temperature as it is discharged from a hot water supply outlet (i.e. shower, tub, or faucet). This phenomenon is present in the operation of all instantaneous, tankless style, water heaters, but is minimized with the high tech design of Rinnai water heaters.
The technology built into the Rinnai water heaters is designed to minimize the cold water sandwich effect. Rinnai water heaters are microprocessor controlled and when water flow through them ceases, they remain in a “ready to fire state” for approximately 1 minute. If water flow through a Rinnai water heater begins within the first minute following water flow stoppage, the water heater will fire back up within 1 to 2 seconds. This minimizes the cold water sandwich effect that would otherwise be experienced with a low tech tankless water heater. It should be noted that the cold water sandwich effect cannot be removed completely from tankless style water heaters. The safety standards developed to insure the safe operation of water heaters require a delay in the ignition sequence of all gas water heaters.
While the cold water sandwich effect cannot be completely eliminated from standard plumbing systems, it can be eliminated from plumbing systems that have a supply and return hot water circulating system. Rinnai has developed 2 methods to eliminate the cold water sandwich effect in residential hot water circulating systems.
The first (and preferred) method to remove the cold water sandwich from circulating systems utilizes a small electric tank water heater (powered up) that is used with a dual purpose. The small water heater acts as a mixing tank to eliminate the cold water sandwich effect from the Rinnai water heater and it uses its electric heating element to offset the heat losses from the hot water circulating system.
The second method to remove the cold water sandwich from circulating systems utilizes a small 2 to 6 gallon storage tank installed on the hot water outlet of the Rinnai water heater. This tank acts as a mixing tank to blend the cold water sandwich with hot water and eliminating its effect at fixtures.
Mar 11, 2009 | Rinnai Water Heaters
Water Heater Innovations MR85245 High Efficiency Electric  Heater Logo
119 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
