Question about Gateway G-MAX2000 2-Piece Multimedia Speakers Computer Speakers
My speakers will not work but they are plugged in and turned on what can I do?
My speakers just stopped working. No power when I turn know to turn on and increase volume
Ir you are lucky it will be your power supply that's gone dead. Use a volt meter to see if the power supply is working or try to find a power supply with the same characteristics (voltage, polarity and amperage). If that doesn't work, the amplifier may be busted. If so you'll need new speakers.
Apr 18, 2014 | Bose Companion 2 Computer Speakers
The speakers quit working/what do I do?
Make sure that it is the speakers that stopped working by unplugging them from your computer (or whatever you have them plugged into), and plugging headphones into the same jack that the speakers were plugged into.If the headphones work, you have confirmed that the problem is with the speakers. If the speakers use an AC adapter (black plastic cubical thing that plugs into the wall), then you might try getting a replacement AC adapter with the same output (AC or DC), voltage, polarity (which side is positive, and which is negative), and connector. If the speakers plugged into a USB port for power, your USB port may have turned itself off. In that case, reboot the computer to see if the USB port will turn back on.
If none of this works, you have to buy new speakers.
Apr 18, 2011 | HP JBL Platinum Computer Speakers
If my speakers don't work, but they are turned on and the speakers are plugged in. The volume on my computer is turned up to almost max.
Plug in a set of headphones in place of the speakers, for testing, and see if they work. This will let you know if the problem is the computer or the speakers.
Feb 24, 2011 | Acer Audio Players & Recorders
I cant get my speakers on my computer to work
Computer speakers are specially designed for a computer desktop environment. They are smaller than normal stereo speakers and often have built in volume controls and amplifiers. In most cases, you can plug in your computer speakers and have them work immediately. Occasionally, however, you will need to adjust your computer sound settings to get them to work correctly.
  1. Step 1 Plug your speakers into each other. Most PC speakers have a detachable cord that goes between them. Powered speakers have a cord that plugs into the wall, which may be detachable as well.
  2. Step 2 126401_thumb.jpg Image Courtesy of: http://www.hardware.windowsreinstall.com/soundcards.htm Look at the sound card output in the back of your computer. If your soundcard has three colored jacks, plug into the green one. If it does not have colored jacks, plug into the one next to the jack with the picture of a microphone. Plug the power supply into a wall socket.
  3. Step 3 Turn on the speaker, turn up the speaker volume and play some music. If it doesn't work, continue to step 4.
  4. Step 4 Turn your volume up on whatever media player you are using. If the music still doesn't play, continue to step 5.
  5. Step 5 Go to the volume settings. If you are using windowsmag-glass_10x10.gif, click Start Menu -> All Programs -> Accessories -> Entertainment -> Volume Control.
  6. Step 6 Adjust the volume settings. Use your mouse to drag the main "Volume Control" slider and the "Wave" slider all the way to the top. If either of them have the "Mute" box checked, uncheck it. Try the sound again.
Nov 14, 2009 | Sony SRS-D21 Computer Speakers
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
Logitech X540 PC speakers, rear speakers only working; LAPTOP
Goodday remmember that you have to have a 5.1 sound card to be able to use a 5.1 sorround sound system.the 5.1 has more plug inputs to plug all the speaker FRONT REAR and SUB.
Jan 03, 2009 | Logitech X-540 Computer Speakers
I have an ABIT computer i plug my headset in and the mic works but the speakers don't ive checked an the hardare says the speakers do work but i cant hear anything. by the way its not sound turned down or...
make sure when you click on the speaker in the bottom right hand corner that your wav volume is also turned up or nothing will come out as well. and always plug speakers ect into green plugins on computers and speakers.
Aug 02, 2008 | Computers & Internet
Can't set up speakers to work with the computer
Hi
Speakers are usually very simple to set up. If they are standard speakers then all you should need to do is plug them in at the mains, and then plug them into the correct port on the back of your computer. There are three holes the same size for speakers/headphones, microphone and possibly video. I'd suggest putting some music on (use windows media player or go to playlist.com) then plugging the speaker cable into each hole in turn - one of them should work. Make sure that the speakers are turned on and that the volume is turned up. Also if you go to Start>>>All Programs>>>Accessories>>>Entertainment>>>Volume Control and make sure that the volume there is set to at least halfway for each and that the mute box is not checked for any.
If this does not work then there may be a problem with your soudcard or with the speakers themselves. Try using headphones and if this works then you know that there's a problem with the speakers.
Hope this helps!
Philip
Jul 14, 2008 | Computers & Internet
Gateway G-MAX2000 2-Piece Multimedia Speakers Computer Speakers Logo
97 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
Tom Chichester
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
