Question about Refrigerators
GE Refrigerator Model GSS25WGTA
Just recently I heard a noise coming from my freezer. In my freezer in the back is a panel which I assume is some sort of control panel. When it is running it glows red and very hot to the touch. The noise seems to be condensation or water hitting this panel when it is on. Now, I don't know if this was always like this but it was just recently I starting hearing the noise. Because of the heat this was giving off, I'm so afraid of it catching fire. Does anyone know if this is suppose to be like this or not and if I'm right for being concerned? GE is coming out tomorrow and charging me $70 for doing so and I want to have some knowledge before they show up.
2 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: I have a GE refrigerator (model # GSH25SGRESS).
Change the control. GE has a number of problems with the original boards.
Posted on Dec 29, 2010
  • 8 Answers
SOURCE: I was hearing a sizzling
This is normal defrosting of the evaporator coil.
Posted on May 13, 2011
The compressor of my GE PFE 29PSDASS floor model comes on for a few seconds then goes off. The lights remain on. What is wrong?
Refrigerator Repair Help ' Appliance Aid
www.applianceaid.com > ... > Refrigerator Help Section
I heard a sizzling noise inside my freezer section and it looked like something ... Myfridge makes a bang noise when it shuts off; My Frost free fridge will not run at all; Myfridge is making screeching/squeak noises; My GE SxS fridge door has ... an amp meter, each compressor is rated in running amps ( see model/serial tag ...
GE Refrigerator Repair Online Manual ' General Electric ...
www.appliancerepair.net/ge-refrigerator-repair.html
FREE ONLINE GE refrigerator repair manual - Diagnose and troubleshoot ... to know basically how the bloomin' thing works, and then get on with fixing it? ... Chapter 5: GErefrigerator problem: Refrigerator is not cold and compressor is ... Do you have somequestions that you would like to ask a professional GE repairman.
Dec 17, 2015 | GE Refrigerators
Tip
Appliance Repair Boise - GE refrigerator making clcking noise
When you hear your GE Profile refrigerator making a clicking noise, coming from the back/rear of refrigerator, your refrigerator control board is bad. If your refrigerator and freezer are still cooling then you are lucky and you might have a few days to get that control board replaced. The clicking sound you're hearing most of the time, comes from a small panel located on the rear of refrigerator. Remove 3 screws and replace.
Rich
Western Appliance Repair Boise
on Oct 11, 2010 | Refrigerators
Refrigerator side not cooling. The freezer works fine. Its age is over ten years old. Model GE TFX22R.
Is there any frost build up on the freezer panel? If not, this could be a damper door issue. Check to see if air is coming from the damper, this is the vent inside the back left-corner of the fresh food side, assuming the evap fan is running. If you feel nothing, it more than likely is your damper door.
If you have frost build up, we're talking about a defrost issue then. Let me know!
Mar 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Noise high pitch noise from the freezer on my side by side
Hi, Remove the rear inside freezer panel and you will be able to see the evaporator fan motor. The fan motor is what is squeeling.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Groaning noise on GE side by side refrigerator
Usually the groaning noise is from a locked up icemaker. Remove the icemaker and defrost it with hot water. Check to make sure the unit is in good shape and not chipping. Let it dry out and then reinstall.
Jan 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Unusual fan noise
YOUR FREESER FAN IS GOING BAD ,REMOVE FREEZER PANEL TO EXPOSE FAN,HOLD FINGER ON FAN,RELEASE IF FAN DOES NOT START REPLACE,THANKS-MIKE
May 29, 2008 | GE GSS25SGMBS Side by Side Refrigerator
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Hello Michael,
Thanks for your question, I hope I can help some. My answer is long winded but full of good info.
The noise could be as the GE guy said refrigerant (gas) noise. If it is refrigerant noise it happens as the liquid refrigerant comes out of the tiny capillary tube and enters the evaporator (cooling) coil in the freezer. Along with the liquid coming through the capillary tube there often are gas pockets. The flow of the liquid and gas pockets into the evaporator coil cause strange sounds. If the noise you are hearing is this refrigerant noise, you should only hear the noise while the compressor is running and then only for a short time (1 to 2 minutes) after the compressor shuts off.
If the noise continues after that I do not think it is a refrigerant noise.
There are times when the compressor will not be running but the fan in the freezer will be running on this model. This is normal and working properly but if the noise is present when the freezer fan is running and the noise stops when the freezer fan stops, the likely cause will be the main board located in a square panel on the rear of the refrigerator above the compressor compartment. I know that sounds crazy but the main board can cause the freezer fan motor to make some really strange noises. Eventually the board will probably fail.
One other test would be for you to listen for the compressor to turn off, then if the noise is present after the compressor turns off, you would next unplug the refrigerator from the receptacle. If the noise continues with the refrigerator unplugged it must be refrigerant noise. If it stops, I am betting on a bad main board.
I tried to locate for you information on a material that Whirlpool and Frigidaire as well as some others use as a noise deaden-er that they wrap around where the capillary tube enters the evaporator. I was not successful in locating anything. I am sorry I could not find it.
supertechks
Please don't forget to rate me
Jan 25, 2008 | Jenn-Air JFC2089HE French Door...
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
304 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Gere knutson
