Question about Brother HL 2140 Laser Printer
I had a paper jam and had to remove the toner cartridge to fix. After replacing the toner cartridge the 'replace toner cartridge' light stays on and won't print. Do I truly need a new toner cartridge or is because of the paper jam somwhow?
    Genius:
  • 1,570 Answers
THERE IS STILL PAPER JAM IN THE PRINTER OR YOU NEED TO TURN IT OF BEFORE PRINTING AGAIN.
Posted on Nov 11, 2010
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
HP Laserjet 1320 replaced cartridge, toner light stays on
it may be not a genuine one, or you have a paper jam inside the printer
Mar 25, 2010 | HP LaserJet 1320 Printer
Paper jam light will not go off and there is not paper jam in the unit.
Over time paper dust and toner residue can build up around the drum and paper feeder rollers. Open your printer and remove the toner cartridge and Drum unit. Use a soft brush to clean any residue. Replace toner cartridge and drum unit.
A tiny bit of paper can cause the paper jam light to stay lit.
Jan 16, 2010 | Office Equipment & Supplies
How do I fix a paper jam?
Step 1
some or all of the jam.Many printers provide an error-code listing
on the front panel display for the area where the jam occurred.If
your printer shows an error code, be sure and check the printer
manual to see if that identifies the area of the printer where the
jam occurred.
Step 2
Step 3
Step 4
Open any other doors that give access to the printer's paper path
and to the toner or ink cartridge.
Step 5
If necessary,remove the toner or ink cartridge.Place it in a bag
Step 6
If you find a piece of jammed paper,remove it by holding it with
both hands and pulling firmly.If several pieces are jammed together
Step 7
If the paper does tear,try rotating the roller gears manually to
free the paper.
Step 8
Replace the toner or ink cartridge and paper trays,close any doors
Step 8
If the printer paper jam message still appears,then there is still
some paper in the printer.Reinspect the paper path.
Oct 28, 2009 | HP DeskJet 810c InkJet Printer
Printer will not work after paper jam fixed
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 09, 2009 | Canon iP4500 Photo Printer
How to fix paper jammed error of canon mp145
Please try this
alternative :
Jun 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
My NEC 870 laser printer has paper jam. How can I fix it?
Open the top printer door by pressing the round release button on the left side of the printer. Remove the toner cartridge (numbered 2) and the photoconductor cartridge (numbered 1) from the printer. This will give you full access to the paper path and you should be able to remove the jammed paper. If you pull on it and it begins to tear or is feels like it is caught on something, remove the paper and paper tray from the front of the printer and try to reach and remove the jammed paper pulling it back out the direction it went in.
With the jam removed, replace the paper tray and paper, re-install the photoconductor (#1) and the toner cartridge (#2) into the printer and close the top door. Make sure you get the door closed firmly and that it catches otherwise you will still have an error light and not be able to print.
That should fix your problem... good luck! :-)
Jan 31, 2009 | NEC SuperScript 870 Laser Printer
MAKER PAPER IS JAMED IN PIECES HOW CAN I FIX IT
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine. ..
Jan 17, 2009 | HP Officejet 6310 All-In-One InkJet...
Paper jam.
try this, its probably a small part of jammed paper inside or then theres a problem with the paper pickup, try cleaning it.
alternative :
Oct 26, 2008 | Lexmark X83 All-In-One InkJet Printer
Brother HL 2140 Laser Printer Logo
254 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
