Question about Canon iR 2016i Black and White Copier
My canon ir2018 is giving the following error e007. Pls assist.
  • Canon Expert
  • 231 Answers
E007-0000 ABNORMALLY LOW TEMPERATURE (detected by sub thermistor)
A fixing film sensor failure has been detected.
Fixing film rotation error
C:
Fixing film sensor failure
The fixing film sensor is faulty.
R: - Check the connector of the fixing film sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Posted on Nov 11, 2010
SYSTEM ERROR E007 ON CANON iR2018
Call to 1-800-243-0019 Canon ir 2018 system error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film.
Apr 15, 2017 | Canon Office Equipment & Supplies
Where do i find the fixing film?of the ir2018 canon printer. what does it look like and how do i replace it? mukopaje@live.com
hi,
please do following
m good with laser printers but when it comes to copiers. ... I have a Canon IR2018 MFD copier. It started giving me the e007 error. I know this has somthing to do with the fixing film. ... Does anyone have a service manual or a technical diagram of a canon ir2018 copier.....that would help alot. ...
www.copytechnet.com/.../canon/41455-canon-ir2018-fixing-film-replacement.html - Cached iR2018 fuser replacement... Repost for mnamono‎ - 7 posts - 27 Oct 2010
IR 2018‎ - 9 posts - 20 Apr 2010
More results from copytechnet.com »
May 30, 2011 | Office Equipment & Supplies
MY CANON iR2018 PRINTER COPIER IS SHOWING AN E007 ERROR. I CAN'T PRINT OR PHOTOCOPY
The error E007 code means that the fusing film is worn out or damaged. Worn out is self explanatory, Damage will generally happens when a jam is cleared incorrectly (forcibly or by sticking something like a butter knife into the machine "Do not laugh, I have seen it!"), You will need to most likely have the fusing film replaced. This is beyond most users, you are probably going to have to get a service center to repair it.
Sorry, but I hope this helps
Dec 22, 2010 | Canon Office Equipment & Supplies
My canon printer iR2018- error E007
E007 0000 Fixing film sensor failure
Nov 10, 2010 | Toshiba e-Studio162D Copier
Cannon ir2018 system error E007
E007 is fixing film problem. Worn-out fixing film.
Sep 28, 2010 | Canon iR 2016i Black and White Copier
How to fix my canon IR2018 system error E007
this error is normally related to the hot roller in the machine
Feb 23, 2010 | Canon Office Equipment & Supplies
For 3 days now, my canon iR2018 has been showing a warning light that says system error and the error number on it is E007.
Hello sir; Sorry for delay, E007 is a fuser problem, it can be reset ;
press "additional function" "2" and "8" keys in that order, SSSW will display, press "OK" enter 1 using up/down arrow key,then enter bit switch 1 by using left/right arrow key, then change value from 0 to 1 or from 1 to 0,press "OK", press "stop", to end the service.
Nov 09, 2009 | Canon Office Equipment & Supplies
Error code 007 appears on my canon iR2018
Hello sir; You may go to make a reset procedure as follow; press "additional funtion"(*) key "2" and "8" key in order, then sssw will display, press "OK" key, then select menu item 1 using up/down arrow key, select bit switch 1 using left/right arrow key, then change data from 0 to 1 or from 1 to 0, then press OK, press Stop .
Sep 16, 2009 | Canon Office Equipment & Supplies
System error e007
That code means that the fusing film is out of Home Postion or the film is ripped. You will need to most likely have the fixing film replaced. You are proble going to have to get a service to repair it.
HE PROBLEM IS WITH THE FIXING FILM, IT HAS A SENSOR ON ONE SIDE THAT IS WERE THE FILM IS TORN. REPLACE THE FIXING FILM
Mar 15, 2009 | Canon iR 2016i Black and White Copier
Canon iR 2016i Black and White Copier Logo
321 people viewed this question
old marine
old marine
