Question about Refrigerators
My fridge is not getting cold. Adjusted temp. Freezer is fine
  • 1,344 Answers
There a few things that could be going on. First thing to check for is if the fan in the freezer compartment is running. If it is, while you have the freezeropen, look on the back wall to see if you h ave a build up of ice/ frost on it. If you deo this means you have a defrost problem which consist of defrost heaters, bi-metal thermostat which connect to the heaters and a defrost timer. Depending on the machine, which part wrong could very. Most commonly it will be the defrost timer and or bi-metal thermostat. If none of this is happening the air damper which lets air flow from the freezer side to the fridge could be shut not letting cool air to pass.
Posted on Nov 11, 2010
Why is freezer way too cold and fridge too warm when the temp display actually states the preferred temp?
Check the fan in the freezer section, its probably not working or turning too slow. Also check the fresh food cold adjustment its really just a door that gets adjusted, but it could be blocked with food, stuck or broken.
Sep 01, 2014 | Refrigerators
Freezer is working fine. Bottom Control for Crispers working fine. Upper section of fridge not getting cold.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
May 26, 2011 | Frigidaire Refrigerators
Food keeps freezing in my fridge. Even at the lowest temp.
in the fridge compartment check behind the control panel where the light bulbs are remove this cover and make sure the damper vent door opens and closes when adjusted with the fridge control sometimes they ice up from condensation and freeze in one position and this may let too much cold air in from the freezer for too long,otherwise it also could be a defective electronic control board in this same area
May 13, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
The refrigerator doesnt stay cold. freezers fine. the refrigerator will get cold if you don't use it for a long time
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 04, 2009 | Refrigerators
Freezer works, fridge part does not
Aug 21, 2009 | Refrigerators
Fridge side is not cooling, freezer side is fine
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 08, 2009 | Refrigerators
The refrigerator doesn't make it cold enough to keep food fresh, even with adjusted level to 9
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | Refrigerators
I have a jenn air side by side. the freezer is
This is usually a sign of a defrost problem. I will need you model number to help you better. Sea Breeze
Jun 26, 2009 | Jenn-Air Refrigerators
Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Mar 13, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
