Question about Desa International Heating & Cooling
HAVE A CAST IRON GAS FIRE PLACE INSERT ,MODEL SVYD18PR, PILOT LITE GOES OUT IF I MOVE THE THERMOSTAT UP TO 70 DEGREES,
  • Desa Interna... Master
  • 8,220 Answers
That insert must have a milli-volt gas valve. The safety feature used on them type valves is a Thermophile/generator. When these generators get weak they will hold the pilot but when called upon to operate the gas valve solenoid they simply die. Replace the pilot generator.
MILLI-VOLT OPERATION
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 11, 2010
  • Dan Webster
    Dan Webster Nov 11, 2010
    Now IF your insert is an ODS system (I have no way of knowing exactly
    where to look for that model number by the way) If the insert uses the
    popular Oxygen Depletion System safety then your pilot is dusty inside.
    The oxygen is lowered inside the dusty pilot safety and so it does it's
    job and shuts down like it's supposed to. What I do is flush out the
    pilot with a little rust buster. Then wait till that drys. This keeps
    from messing with the pilot flap and damaging the pilot. This page
    shows where to clean and includes a video of how it works
    ODS SYSTEM
Fireplace with Eurosit gas valve. Pilot is lit but fireplace only kicks on if an ice pack is applied to the probe.
icing at the jet indicates that there is liquid gas at that point and as it tries to boil off into gas the surrounding humidity is freezing the hole (jet)
get a gas appliance fitter in to check the regulator and the system for faults and go from there
Sep 01, 2015 | Heating & Cooling
Gas fire wont stay lit
The thermostat probably reached the set temp, but maybe the pilot lite blew out. Or the control needs to be replaced.
Nov 25, 2013 | Kitchen Appliances - Others
Fryer does not shut off when temp .is reached
I assume it is a gas model. There are 2 thermostats. One is adjustable, you set your temp, it sounds like it has gone bad.. The second thermostat is the high limit thermostat. When it reaches 450 degrees F, it will shut down the pilot and main flame to prevent a grease fire. It may be possible that someone has hooked the thermostat up wrong. Next time you fire it up, disconnect one of the thermostat wires that has the temperature knob. If the flame goes out, the thermostat is bad,
Oct 04, 2010 | Imperial IFS40 Deep Fryer
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Flame goes out Monessen Ventless fire place Model DLX24.
take a needle and put it into the end of the gas pilot hole. Wiggle it around in there, it just might have dust build up in there. Hope this helps ya.
Jan 17, 2009 | Stoves Monessen Variable Thermostat...
Pilot going out when thermostat turned on
This is caused by the safty bypass feature on the gas valve. You will need to replace the gas valve. This problem is a safty interlock built into the valve when it fails it will not let the main valve portion fire.
Aug 23, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
43 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
vance jones
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
