Question about Gateway ACT Refurbished LUCENT /CLARENT/ACT SDM 9350 V352 ACT (SDM9350) Firewall
ACT/SDM 9350 MULTIPLEXOR
I´m looking for an ACT/SDM 9350 multiplexor whit Minimum characteristics:
3 ports RS232, 9600 bps
2 port VoiceIP FXO/FXS
1 port E1 2048 kbps, G.703 interface
1 port for configuration.
Do you have this or any compatible mux?
I have 1 ;)
a netperformer SDM-9350
I realy dont know its specs but you can contact me at glenns@aapt.net.au
Posted on Aug 30, 2008
Cannot reset to factory default
Are you unplugging ethernet cable from MP? make sure you do otherwise factory reset will not work.
May 22, 2012 | AudioCodes MP-114-FXO - 0 FXS Ports, 4 FXO...
I have a 1 port fxs voip voice modem, i have connected it and it is working. but the problem is that any time i power off my pc, i will have to reprogram it. can any body help me please?
the pc and ata are not reliant on each other. ensure the ata is plugged directly into you router.
unplug the lan lead and do a factory reset the ata via the ivr. once the unit has restarted plug in the lan and get the ip address via the ivr. set up the ata, rebooting after each page update (do not update more than 1 page before rebooting the ata).
you should now have a functioning ata and should be able to turn off your pc without issue.
if the ata now loses its settings then it is probably faulty (I've had a couple of ht386s go faulty in a similar way).
Apr 03, 2011 | Gateway 1-Port FXS/FXO VOIP (MTSMVP130)
Hi i want connect a 7730 phone call to fxs port dvg 5008 .. what settings should i do?
A 7730 is a Panasonic system phone. It requires a Pana system to operate, so I'm confused as to what you're asking. If the phone call is INTO a 7730 phone and you want it to a phone on the DVG, you will need something to transport it, like an FXO circuit tied to the Panasonic's station ports. If the phone call is FROM the DVG and you want to answer it on a 7730, you plug the FXS ports into the CO ports of the Pana Key Service Unit that the 7730 is plugged into.
Hope it helps.
Carl
Mar 13, 2011 | Panasonic KX-T7730 Corded Phone
I purchased a Motorola KRZR2 from Ebay, and although it works great, it cannot connect to the AT&T web. AT&T told me that since I didn't buy it from them, they will not help me out. What are my...
Your WAP and MMS need to be set up.
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
4. Click Web Sessions
5. Click [New Entry]
Fill in the following fields: (some of the fields may already be setup)
Homepage: http://home
Service Type 1: WAP
Gateway IP 1: 10.250.250.250
Port 1: 9201
Domain 1: <leave this blank>
Service Type 2: WAP
Gateway IP 2: 000.000.000.000
Port 2: 8080
Domain 2: <leave this blank>
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Timeout: 5 minutes
CSD No. 1: <leave this blank>
User Name 1: <leave this blank>
Password 1: <leave this blank>
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: <leave this blank>
User Name 2: <leave this blank>
Password 2: <leave this blank>
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name: <leave this blank>
Password: <leave this blank>
Click Done
Click Menu
Select "Set Default"
Then...
1. Click your Menu
2. Click Settings
3. Click WEB ACCESS
Homepage: http://mmsc.mobile.attwireless.net
Gateway IP: 10.250.250.55
Port 1: 8080
Domain 1: blank
Service Type 1: HTTP
Port 2: 0
Domain 2: blank
Service Type 2 WAP
Time out: 5 Minutes
CSD no 1: Blank
Username: 1: blank
Password 1: blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: blank
User Name 2: blank
Password 2 blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: proxy
User Name:blank
Password:blank
Press the left soft key 4 times to return to the main menu.
Scroll to and select Messages.
Press Menu.
Scroll to and select Inbox Setup.
Scroll to and select MMS Message Setup.
Scroll to and select Server Info.
Scroll to "AT&T MMS", then press Menu.
Scroll to and select Edit.
Validate the following settings:
Service Name: AT&T MMS
Server Name: http://mmsc.mobile.attwireless.net
Web Session Name: AT&T MMS
Jan 14, 2010 | Motorola Mobility KRZR K1 Cellular Phone
No internet connection it is a unlock phone from t mobile to att
Hai, Go into Web Sessions and change the Internet and MMS settings to those appropriate for AT&T. If the T-Mobile settings are locked, create new settings and make them the the default. Each carrier has its own setting but those settings are the same for any phone on that carrier's network.
Browser Settings (in web sessions): ---------------------------------------------------------------------------------------------------- Name: Cingular Wireless Internet
Homepage: http://device:home or http://device.home Service Type 1: WAP Gateway IP 1: 66.209.11.61 Port 1: 9201 Domain 1:  Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 9201 Domain 2:  DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 15 minutes CDS No. 1:  User Name 1:  Password 1:  Speed (Bps) 1: 9600 Line Type 1: Modem CDS No. 2:  User Name 2:  Password 2:  Speed (Bps) 2: 9600 Line Type 2:  GPRS APN: wap.cingular User Name: WAP@CINGULARGPRS.COM Password: CINGULAR1 ------------------------------------------------------------------------------------- MMS Settings (in web sessions):
Homepage: http://mmsc.cingular.com Service Type: WAP Gateway IP 1: 66.209.11.61 Port 1: 9201 Domain 1:  Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 9201 Domain 2:  DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 15 minutes CDS No. 1:  User Name 1:  Password 1:  Speed (Bps) 1: 9600 Line Type 1: Modem CDS No. 2:  User Name 2:  Password 2:  Speed (Bps) 2: 9600 Line Type 2:  GPRS APN: wap.cingular User Name: WAP@CINGULARGPRS.COM Password: CINGULAR1 ------------------------------------------------------------------------------------------------ MMS Settings (in Message Center>>>Message Setup>>>MMS Message Setup): Hide fields: Cc.Bcc.Priority Autosignature: Download: Automatic Filter: Expire After: 5 days Reply Type: MMS Size Limit: None Server Info: Cingular MMS>>>Select Server Info>>>Current Server>>>New: Service Name: Cingular MMS
Server Name: http://mmsc.cingular.com Web Session Name: Cingular MMS.
Some settings may not have to be entered for all phones because they are set at the default for those models. You can leave the User Name and Password fields blank.
Aug 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Gprs/ wap setting for PDA pocket PC phone
Google "GPRS" "Settings" and your provider name. (T-Mobile or AT&T) You should find a lot of answers. Here is one that works for me even though Cingular isn't their name anymore:
Homepage: h t t p :// device.home «--remove spaces
Service Type 1: WAP
Port 1: 80 --NOT 9201
Domain 1: <blank>
Service Type 2: WAP
Gateway IP 2: <blank>
Port 2: 0 --NOT 9201
Domain 2: <blank>
DNS 1: <blank>
DNS 2: <blank>
Timeout: 15 minutes
CSD No.1: <blank>
User Name 1: <blank>
Password 1: <blank>
Speed (Bps): 9600
Line Type 1: Modem
CSD No. 2: <blank>
User Name 2: <blank>
Password 2: <blank>
Speed (Bps) 2: 9600
Line Type 2: ISDN
Password: CINGULAR1
I hope this helps.
May 07, 2009 | Computers & Internet
Can u tell me function of DSP , LGS CARDS IN 3600
LGS is same with FXS (Foreign eXchange Subscriber) card. It's voice card for serving voice needs with 2 wire connection. A analog phone connect to LGE on alcatel 3600 and other analog phone or PBX on remote alcatel 3600.
Look the others card e.g LGE (FXO) and E&M card.
DSP card processed the voice.
thanks
Feb 26, 2009 | Alcatel Newbridge MainStreet 3600...
Help me please!!
  1. Validate the following:
    • Name: MEdia Net
    • Homepage: http://device.home
    • Service Type 1: WAP
    • Gateway IP: 66.209.11.61
    • Port 1: 9201
    • Domain 1:leave Blank
    • Service Type 2: WAP
    • Gateway IP 2: 000.000.000.000
    • Port 2: 9201
    • Domain 2: blank
    • DNS 1: 000.000.000.000
    • DNS 2: 000.000.000.000
    • Timeout: 15 minutes.
    • CSD No 1: 14152441012 or 18472549271
    • Username: WAP@CINGULAR.COM (required for CSD use only)
    • Password CINGULAR1 (required for CSD use only)
    • Speed (Bps) 1: 9600
    • Linetype 1: ISDN
    • CSD 2: leave Blank
    • Username 2: leave Blank
    • Password 2: leave Blank
    • Speed (Bps): 9600
    • Line Type 2: ISDN
    • GPRS APN: wap.cingular
    • Username: WAP@CINGULARGPRS.COM
    • Password: CINGULAR1
  2. Click Done
Nov 20, 2007 | RIM BlackBerry Pearl 8100
AFTER CALLER HANGED UP PHONE, THE REMOTE SITE STILL RINGING
A long standing problem with FXO's and FXS connections is the latency in Voip and signaling. That is there is a delay from the time sent to time received. There should be software settings to adjust the delay. I would refer back to the manufacture of the FXO card and see if there are any software patches or upgrades. This is a software problem.
Jan 18, 2007 | Gateway ACT Refurbished LUCENT...
Computers & Internet Logo
597 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
