Question about Seagate USB 2.0 External Enclosure + 400GB ST3400832A UATA 8MB 7200RPM HDD (NEWITEM31875736) Drive Case
My seagate 250GB hard drive suddenly stopped working today. i have work and other personal files on there which i carry around. I do leave it in my bag which i take to school, but i don't drop it. I plugged it into the crappy school computers which i am currently using. When i plug the HDD into the computers it makes a bleeping sound. 2 bleeps per second and isn't booting up. I looked around and found it doesnt work with USB 1.0 usb's, but i have used my HDD on these computers before. I am seeking immediate assistance. Thanks
I have a HP Pavilion dV5t-1000 laptop with a Momentus 5400.4 hard drive. All was working fine until today. The computer is now telling me the hard drive does not exist. I connected it to my custom built...
No, the disk doesn't appears in My Computer because the file system on it is completely corrupted - all the data is lost. To see if the hard disk itself is recoverable download, install and run this free program (select the correct disk for testing)
http://www.hdtune.com/files/hdtune_255.exe
Feb 03, 2011 | Seagate Momentus 5400.4 250GB SATA/300...
HERE MY 250GB SEAGATE HARD DISK IS SENSING BUT WHILE COPING ANY FILE OR WORKING IN THAT HARD DISK FOR A LONG TIME IT WILL DISABLE AUTOMATICALLY, THEN I CANT ABLE TO WORK IN THAT. KINLY ANY GUIDE ME HOW TO...
Hi Welcome to Fixyah,
Try to disconnect that and then check if the surface is hot then it will not take to work in a longer time. Suggest for that is try to put some heat sink and then try to connect also using other USB port. But sometimes the real problem is the enclosure and not the hardisk.
Aug 12, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Suddenly stopped working
i think your hdd is dead,Because your hdd light not even turn's on....
Apr 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Drive not being recognised by any computer.
USB drives do pack it in. You have answered your own question, I think. Three computers cannot recognize it, must be the drive.
A fall can happen and not leave a mark. A fall to the floor is like a bomb going off for a hard drive. It sounds as if the motor is jammed.
Mar 30, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
My 250GB HD250HJ SATA has stopped booting with my other 160gb seagate,i have xp sp3 with amd 4600+,while booting eindows diskcheck starts and finishes after about 1 hour,onnce done it just stays that...
It sounds like your hard drive is messed up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 31, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Seagate 250Gb external USB hard data read/write error
Well, in your case I think you can try some so-called data recovery software. It's pretty much cheaper then data recovery services.
First of ALL - Connect your external hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem! Remember - Always make Backups of your precious data!
Mar 05, 2009 | Computers & Internet
STECH 320GB Corrupt Boot file
sure..take it to a recovery expert..they love this sort of work..not cheap..but highly effective..
and you may wish to consider backing up that external drive in future.
May 25, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Seagate FreeAgent Pro Desktop 250GB - no power
I have a seagate freeagent pro 320 gb. worked fine for over a year. all of a sudden no power at all. Plugged it into my 12v dc adapter from a western digital external HD and it works fine . I am calling Seagate tomorrow for a replacement plug.
Jan 20, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
Computers & Internet Logo
59 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
