Question about RCA Lyra M2030 MP3 Player
My rca mp3 model m202 will turn on and when i push a button it doesnt do anything
Dat file
first you should try and locate the files on the mp3 player all the music and whatever else is on there and back it up to the hard drive, then goto the rca website and find the latest firmware for your player and download it and reload the firmware that should get everything back to factory defaults
Oct 04, 2009 | RCA M2000 MP3 Player
It doesnt turn on just the blue light on the wheel
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 29, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
I can't seem to turn on my Samsung YP-T7J MP3 Player
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
Nov 30, 2008 | Samsung Yepp YP-T7JX MP3 Player
Help!!
thats because when you turn it on you are u are pushing it over too far. you push it over barely to turn it on. look closely at the button that turns it on and you will see it
Oct 18, 2008 | RCA TH1101 MP3 Player
Wont turn on
i just got one and it was the same thing ever once in a while it would come on for me but now i just pushed the power button really hard and it seemed to work for me.
Aug 20, 2008 | RCA H100 MP3 Player
Ineed original software for my RCA M202E mp3 player, as well as a DELL DJ 512 MB mp3
Hello rafito229
Drivers, software and firmware for the Dell DJ and Pocket DJ can be downloaded from the Dell website at this link.
According to the RCA website (www.rca.com) there are no downloads available fo the M202. I'd recomend contacting RCA directly at 1-800-336-1900 to see if they can provide the software you need.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 17, 2008 | Audio Players & Recorders
Rca 52" hdtv
What model RCA do you have? There is a difference from diagnosing the DLP and CRT projection units. Let me know the model number.
Jan 20, 2008 | Televison & Video
RCA TH1011 MP3 player
After it is turned on, you need to push the power button again to begin playing....To shut down, hold the power button....
It's not the best player!
Dec 02, 2007 | RCA TH1011 MP3 Player
RCA MP3 M202E
ok... when your looking at it from the front (screen forward) on the right there are 4 buttons.. the top button is play/pause push that the turn on the mp3 player. underneath the play/pause button is the stop button this stops the song and when you hold the stop button down it turns off the mp3 player. the next buttons are the skip forward and skip backward buttons.. on the left side, the very top button the longer shaped one is the +/- volume button. underneath the +/- button is the equalizer button push this to changed the sound of the device.. and the last button i have yet to figure out.. i hope this helps you..
Jun 19, 2007 | RCA Lyra M2030 MP3 Player
RCA Lyra M2030 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
