Question about Vacuums
Good day i have a MABE STOVE Mod# X06500PX0 and I am looking for the knobs that turn on the gas to lite the stove.
  • Vacuums Master
  • 17,970 Answers
Its possible that you can find KNOBS replacement in THIS LINK.
Hope helps.
Posted on Nov 11, 2010
Chef mate butane stove, CM1000 by Keromate, is leaking when I try to install butane canister.
check for a missing very small
"O" ring around the area where the canister fits to the stove
could be the seal where the canister goes in is damaged
Jan 22, 2017 | Vacuums
Hi, my husband bought me your KAMENSTEIN WORLD OF MOTION SERIES ANIMATED HORSE CAROUSEL many years ago. I did not keep the box or manual and now I want to ask can you e-Mail me a download or one I can...
I cannot loacte an actual manual but....The Kamenstein Carousel teapot was part of the MKI versions of teapots Kamenstein released in the mid-2000s. The teapots came in a range of colors, from blue to red, and they had a small carousel on the top. As the water boils the carousel spins around, bringing an element of whimsy to your tea time. The teapots are all metal and can be used on any type of stove top.
Instructions
    • 1 Fill the Kamenstein Carousel teapot with water just below the sprout.
    • 2 Place the Kamenstein Carousel teapot on the stove and set the heat to "Medium."
    • 3 Allow the water to come to a boil and remove the Kamenstein Carousel teapot from the stove.
    • 4 Pour the hot water into a cup over a tea bag.
Read more: How to Use a Kamenstein Carousel Teapot ' eHow.com http://www.ehow.com/how_7718254_use-kamenstein-carousel-teapot.html#ixzz1JAQxUJn2
Thanks
Apr 10, 2011 | Vacuums
I can not figure how to remove the microwave from the outer bracket. We are trying to replace with new GE microwave but can't remove the old one from over the stove.
Sorry to read about your problem, I hope this helps you out.
you did not list your model, so
Turn off power to unit
1 way. you will have 2 to 3 screws ontop of the unit, open the cupboard door above unit, and look for them. remove all the screws, KEEP UNIT PUSHED AGAINST THE WALL, it will not drop down.
once all 2 or 3 screws are gone tilt unit down a little and lift up and away from wall (TWO PEOPLE)
2nd way if you dont see any screws on top, is look at the upper panel, remove if you can, or look for silver type round screw heads... if you see them..loosen them..unit will become loose from the wall. one on each side.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Vacuums
Are the metal tube lines from the knobs to the burners supposed to be attached?
This is a very intersting vacuum cleaner you have my friend.
If this is n fact not a vacuum cleaner ... but rather ... a stove ... no ... the metal tubes are not solidly connected to the knobs and burner.
Dec 07, 2010 | Vacuums
I have a 1993 fleetwood bounder i have had it for two months. i just got around to the propane appliances but there is no propane flowing to the stove or the furnace. the tank is turned all the way on but...
Ok, Lets start at the beginning. First make sure there is propane in the tanks! Gas can leak rom these tanks sometimes at a very small rate and over time they can go empty if there is a loose fitting somewhere. When you turn on the stove is there any air or hissing sounds coming from the burners? Air can get in the lines and when you turn the gas on, you get nothing but air for several seconds till the air bleeds out then you get the gas. Hold a lit match next to the burner and watch to see if there is any movement to the flame on the match, movement would let you know if there is any air coming from the burner, hold it there for a few seconds and see if any gas comes thru and this will then lite the burner. I always have to turn my stove on for a while to get gas thru the lines so the appliances work after the tanks have been filled or after it sits for a while. Once you get gas thru to the stove you can try your heater, this may also take sewveral tries till all the air is purged from the lines so don't get frustrated, sometimes this can take a while! Then the next thing is the water heater, the gas valve on these has a selection for pilot lite, turn the red knob so thet the cut out in the knob lines up with the gas valve and you have to push and hold this down for a minut or longer to get gas to the burner. Once the burner lights hold the pilot knob down for another minute to make sure all the air is out of the system. Once these are done you should be good to go till next time your tank runs dry and has to be filled. If you determine there is gas in the tank but it is not flowing to the appliances, double check all the shut off valves. The tank should have a diagram on the valve to let you know which way it turns for on and off. Do you have a built in tank on this model? If you have the two removable tank set up, make sure the auto switching valve is set correctly and you have it on to the tank that is full. If you still aren't getting gas, try calling an RV dealer and ask them if there is another valve somewhere that might need to be turned on. There migt be a shut off in the line somewhere, but this is not common.
Nov 15, 2010 | Vacuums
Jm3 hoover just cut out a few days ago,its not the fuse,can anyone help ,thanks
If the fuse is good. You may want to take a test light or voltmeter and check your power switch to see if it is good. If it is good, then you will want to do the same with the power supply and mabe the power cord as well
Sep 28, 2009 | Vacuums
Blowing stuff out the back
It sure sounds like your filter broke. Replace the filters.
May 29, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Motor for Eureka upright model 2315, new in 1977
If the motor is obsolete which it appears to be, have you considered repair?
Write my shop at service@emrrepair.com, with enough information on the failure mode we can get you a close estimate, some of these older vacuums just cannot be beat, for performance, power, etc, We traditionally do not do retail work, but with the current conditions, and woodburning stove blowers rendering perfectly good stoves into land fills, and replacement costs of over $3000,. we have repaired many blowers and fire eyes from $50.00 to $159.00, it all depends on the degree of damage, but we are trying our hardest to salvage some very nice older equipment, let us know, references or see me at allexperts.com. Will Babbitt
Dec 12, 2008 | Eureka 2271 Bagged Upright Vacuum
Vacuums Logo
77 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
